water leak at supply line hole in foundation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by MartGio, May 4, 2013.
  1. MartGio
    MartGio New Member
    May 4, 2013
    St. Louis, Mo.
    I have water dripping in during heavy rain where the water supply line comes thru the foundation. Outside is underground with a large concrete porch across front of house. MartGio.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I would use water plug cement. This fast setting cement is made to plug cracks and hole even with there is water running. You mix a small amount with water to make a stiff dough. Then push the dough into the hole or crack. Cracks should be chiseled out a bit. I believe the directions say to make a / \ notch, but I've found that is a bit hard to do and just opening the crack a bit will work. Mix only a small amount at a time and work fast as the setup time is very short and once is starts to harden, you can not add water so you may need to use several small batches rather than just one larger one. If I remember correctly, "Waterplug" is a brand name, but a decent hardware store should be able to point you to their brand of product.
  4. MartGio
    MartGio New Member
    May 4, 2013
    St. Louis, Mo.
    Ok, thanks for your answer, maybe not to bad of a problem to fix, THANKS!
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    Not so difficult, but do use rubber gloves handling the cement. It's got a lot of lime in it and can irritate or even burn your hands.
Similar Threads: water leak
Plumbing Forum, Professional & DIY Advice Inline water filter for coffee maker clogged, leaking carbon out inlet Mar 19, 2017
Plumbing Forum, Professional & DIY Advice water leaking shower room condominium Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Water Main inside has a slow leak Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Does homeowner insurance usually cover water leaking fix(e.g. repipe or reroute)? Nov 14, 2016
