Water just warm, not hot
Discussion in 'Water Heater Forum, Tanks' started by higgledy, Oct 29, 2012.
  1. higgledy
    higgledy Member
    Jan 5, 2011
    21701
    Thanks. My wife does not think my plumber is good either. In the past, I've hired him to remodel a bathroom. His work is neat and I've had no problems with shady workmanship, etc. I guess he needs to beef-up his diagnostic skills. The other thing is that it is difficult to find a good plumber, especially when you really need a plumber. I assume a plumber is more likely to get to your house that day if you have history with that plumber. Is that illogical thinking?
    BTW, the plumber replaced the 3800 Watt element with 4500 Watt element, it was a high watt density, but he did not know that we had hard water. He told me that water heaters he services on the other side of my county he always uses low watt density elements because that side of the county is know for hard water. I never knew my water is hard either till this experience. Now, I know.
    I've learned in life that a good plumber, a good electrician, and a good lawyer are all worth the money they charge. Thanks for the advice.
    Phil
  2. hj
    If there is a "high watt density" for the upper element and a "low watt density" for the bottom, you will be OKAY. But, if the bottom one is HWD, then keep your old elements because you will need them.
  3. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
  4. hj
    quote; Even the pro's sometimes get it wrong on the first try. Hopefully they go good for it.
    I am glad you said "sometimes" because it should be a very rare occurance for a "good plumber", and usually happens when they have multiple problems and one of them is "masking" some of the others.
Similar Threads: Water warm
Water Heater Forum, Tanks Lukewarm water from series heaters Sep 25, 2016
Water Heater Forum, Tanks Hot water recirculation pump sends warm water to cold line. Aug 17, 2015
Water Heater Forum, Tanks Lukewarm water throughout house! Pics and details... Feb 6, 2015
Water Heater Forum, Tanks luke warm water after new water heater install Jan 24, 2014
Water Heater Forum, Tanks Water Heater only Luke Warm Aug 27, 2013
