Water in P Trap - Adequate Siphoning Test
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Aug 7, 2006.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    4 weeks till the cabinets arrive for the kitchen.
    I have a suspectiable issue with my vent .....
    From the stub, can I install and P trap and pour water into it.
    If by week 3, no water disappears and everyone in the house is still using the rest of the houses *plumbing system* is it safe to say that I don't have siphoning issues with my layout ?
  2. jadnashua
    In three weeks, depending on conditions, it could evaporate...not necessarily a good test. Now, if it gets sucked dry in the first week or so - you've probably got a problem. This will do nothing to tell you about other traps that might have a problem when water runs down that trap.
  4. hj
    trap
    Not necessarily, even if it does not evaporate. Most siphoning issues are caused by the sink itself when it drains, and to test that you would have to have the sink connected and be using it.
Similar Threads: Water Trap
Plumbing Forum, Professional & DIY Advice Trap primer on hot water heater constantly flowing Jan 30, 2013
Plumbing Forum, Professional & DIY Advice Toilet "sucking" water from tub trap? Jan 27, 2013
Plumbing Forum, Professional & DIY Advice water line issues between shower and hot water tank drain P-trap Feb 28, 2011
Plumbing Forum, Professional & DIY Advice WH heat trap interfering with Hot Water Lobster? Aug 11, 2010
Plumbing Forum, Professional & DIY Advice Banging water pipes from water heater heat traps? Aug 5, 2010
