Water In Basement. Footer Problem? Advise?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by averagejoe, Mar 26, 2008.
  1. averagejoe
    averagejoe New Member
    Mar 26, 2008
    Good afternoon. My mom has water in our basement and it appears it is coming from the footer. But, there is no sure way to tell. The house is thirty years old and there are no trees near the foundation so this new problem isn't because of something improper in the design. The water also sits near the drain for the sump pump out to the septic tank so the problem could be either or. I'm assuming someone with a camera is the best route to start with. Especially given my mom has been given $10,000 quotes to jack up the basement floor and install a new footer all the way around the foundation.......
    Any advise?
Similar Threads: Water Basement
Plumbing Forum, Professional & DIY Advice Water on outside of PVC vent pipe in basement Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Basement water lines Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Main Water Line Basement Entrance - Does this look OK? Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Check valve needed? Water on floor of basement. Sep 20, 2016
