Water heaters in series
Discussion in 'Water Heater Forum, Tanks' started by Jbel, Jan 18, 2014.
  1. Jbel
    Jbel New Member
    Jan 18, 2014
    Lima, NY
    I'm thinking about installing a second water heater in series with my existing tank. Could someone tell me where the expansion tank should be located, or if I even need one? I have one 40gal electric heater and want to add another 40 gal.
  2. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    Expansion tank can be installed anywhere in the house, on a cold water line. The majority are installed at or near the hot water heater cold water inlet side.
    If you have a closed system heater manufactures and or code requires on. A closed system is where you have either a check valve, PRV or a backflow device installed.
  4. Jbel
    Jbel New Member
    Jan 18, 2014
    Lima, NY
    My home is an old farm house. I just purchased it. It has well water as a source. So far I have a sediment filter before the expansion tank which then goes into my Hague purification and softening system then out to the house. I've switched most of the home over to pex. Will the original pressure tank for the system suffice?
  5. Terry
    Aug 17, 2004
    If there are no check valves between the water heater and the expansion tank, you would be fine.
  6. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    Does the PRV in fact count as a check valve? (Honeywell, if it matters)
  7. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    It would be unusual to have a PRV with a well, unless you were feeding multiple buildings. But if you did, then yes. But then you have a design that should be reviewed.
Similar Threads: Water heaters
Water Heater Forum, Tanks Tight spot for water heaters Jan 16, 2017
Water Heater Forum, Tanks In-line elec water heaters Jan 2, 2017
Water Heater Forum, Tanks Lukewarm water from series heaters Sep 25, 2016
Water Heater Forum, Tanks Run hot water from 2 separate water heaters to one washing machine. Sep 7, 2016
Water Heater Forum, Tanks Water heaters for radiant heat and hydronic air handler Jun 28, 2016
