water heater vent stack
Discussion in 'Water Heater Forum, Tanks' started by fozzy12, Jan 28, 2009.
  1. fozzy12
    fozzy12 New Member
    Jan 31, 2008
    quality manager
    North of Detroit, MI
    I'm running a standard water heater in my garage. It's a 75 gal Brad White with a 4" vent. Do I need to run double insulated vent piping? I temporarily put it in with standard 4 inch vent, through a roof flashing with a storm collar and a cap. I'm getting it inspected and rather going through having it fail, I'd rather change it sooner than later. I have ample clearance where it passes through the roof and also through the second floor flooring.
    I'm in Michigan if that helps.
    Thanks
    Eric
  2. jimbo
    jimbo Plumber
    At every point, including the roof, you must have 6" clearance in all directions to any piece of wood or drywall or other combustible material.
  4. hj
    vent
    Why would you even take a chance with single wall? Use double wall from the ceiling to the vent cap.
  5. fozzy12
    fozzy12 New Member
    Jan 31, 2008
    quality manager
    HJ,
    It wasn't a question of taking a chance with single wall, I didn't know any better. I assumed since the heater had a normal 4 inch stack on top of it, that single wall would be acceptable, leaving enough clearance around the pipe. Since I have found out differently from the inspector who was kind enough to return my phone call, I will be changing it out to double wall tomorrow. It will be inspected, I just wanted it to pass on the first inspection.
    Eric
  6. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    It is awsome that you are having this inspected. I was just wondering did you install this heater on an 18" stand?
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
  8. fozzy12
    fozzy12 New Member
    Jan 31, 2008
    quality manager
    NH,
    Sorry to disappoint you on the wrench throwing, it is installed on an 18 inch pedestal!
    Eric
  9. hj
    heater
    It only needs to be on a stand if it is in the garage. If the city has accepted the latest National Gas Code, and the heater has an FVIR burner, it only has to be on the stand if a car could impact it.
  10. fozzy12
    fozzy12 New Member
    Jan 31, 2008
    quality manager
    HJ
    The water heater is in a separate building but since it has garage doors on it, it needs to be on a pedestal. Here it also needs to be protected from impact. That means either 4 inch steel posts filled with concrete, or a wall. I chose the wall, I planned on it anyway. It is an older heater so it doesn't have the newer burner that can sit on the floor.
    Eric
  11. SewerRatz
    Nov 20, 2008
    Chicago, IL
Similar Threads: water heater
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
Water Heater Forum, Tanks Richmond Water heater code 6 problem Feb 3, 2017
