Water Heater Timer? Gas or Electric? Any recommendations?
Discussion in 'Water Heater Forum, Tanks' started by watergirl123, Jan 21, 2011.
  1. watergirl123
    watergirl123 New Member
    Jan 21, 2011
    Student
    Redding, CA
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    With electric tanks, the timers are essentially useless- the temps don't fall far enough over 8-10 hours to reduce the average heat loss by even a percent or two.
    With gas heaters (which are inherently lossier due to the necessary insultion gaps and convection through the center tank heat exchanger) it's maybe a bit more, but "...a worthwhile investment..." probably not, in most cases. (It might be with propane-fired tanks though, due the high cost of the fuel.)
    What IS a worthwhile investment is insulating the near-tank plumbing (withing 6' of the tank) to at least R4 with closed-cell foam pipe insulation (including the cold feed an the temperature & pressure outledt plumbing), as well as any accessible hot water distribution plumbing. The cheezy 3/8" wall stuff sold at box stores is better than nothing (~ R2) , but in most instances going with 5/8"-3/4" wall goods (online, or from plumbing supply houses, or Grainger). See:
    http://www.leaningpinesoftware.com/hot_water_pipes.shtml
    http://www.leaningpinesoftware.com/hot_water_heater_vacation.shtml
    http://www.leaningpinesoftware.com/hot_water_pipes_pipe_cooling.shtml
    Sometimes the better solution is the lowest-tech.
  4. hj
    Unless the timer causes the tank to become completely cold and keeps it that way for an extended time, the timer does NOTHING to save gas, because the burner just has to run for a single longer time to reheat the tank instead of operating for short periods several times. IF it lets it get cold, and you don't mind having NO hot water, then it will save gas, because it just has to heat a single tank of water, instead of reheating all the water you used, (which could have been MORE than the 40 or 50 gallons the tank holds), while the timer kept it off. And this applies to both electric and gas models.
  5. ballvalve
    Dec 28, 2009
    northfork, california
    A good place to store all your old jackets is on top of a electric water heater. Long underwear makes great pipe wrap also.
  6. hj
    If you expect the jackets to get "warm" forget it. The new heater's insulation does not give off much heat.
  7. ballvalve
    Dec 28, 2009
    I can tell you that under my jacket pile, you could likely poach an egg. Those new heaters leak heat, but the case does not feel warm because its constantly being shed to daylight. The T&P is like a heat sink when left exposed to daylight also.
  8. jeffreyd
    jeffreyd New Member
    Feb 21, 2011
    California
    Gas Water Heater Timers can be useless in certain applications. For less than $150.00 investment it is certainly a good idea to try one out. You will certainly regain your investment. The amount of time will vary. See www.gaswaterheatertimer.com or waterheatertimer.org for more info.
  9. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Only if there is time-of-use billing, can I see any real benefit. Defer consumption to the off-peak billing rate.
  10. jeffreyd
    jeffreyd New Member
    Feb 21, 2011
    California
    Timers have been installed on electric water heaters for decades. They do work in most cases. There is a gas water heater timer available. See www.gaswaterheatertimer.com
  11. energyman1
    energyman1 In the Trades
    Nov 11, 2012
    California
    See the website www.gaswaterheatertimer.com and open the PDF. This shows testing done by Bradford White which shows energy savings up to 36% by using a gas water heater timer. The timer on this website is a great product!
  12. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
    Sure they "work", but are they cost effective is the important question.
    One study in Florida estimated savings of 21 cents per month.
    There is no energy credit that I know of that applies to timers on water heaters. That tells you something.
    If you live in a warm climate then heat recovery units on your air conditioner are great. I turned my water heater circuit breaker off 9 months a year and never ran out of hot water. It recovered the heat removed from the home and used it to heat the water in the tank. It also increased the efficiency of the central air by 5%.
    Jerry
  13. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    And that's in a Southern state where it costs more to cool than it does to heat. In many other parts of the World, the small amount of standby heat loss is not really lost, it is heating the house.
  14. hj
    Interesting that BradfordWhite would endorse that timer, because it will NOT work with their thermostats. Again, however, if the gas burner turns back on before the tank gets cold, then you saved NOTHING, because the burner will have to reheat the water you used, regardless of whether it is one long burn, or several shorter ones. It is only when the tank goes cold and you continue using the cold water that you save money, because when the burner comes on it only has to heat the water in the tank, NOT all the water you used after the hot water ran out.
  15. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    It's not exactly nothing- the standby losses drop with tank temp even when you're not using the tepid water in the tank. On lossy atmosheric drafted gas HW heaters automatic setback might have some advantage- the temp would drop more than 10F overnight, for a lower average standby loss. The less lossy the water heater, the less you'd get out of a setback strategy.
    The only time the savings outlined in that PDF hit 36% was in the very low volume use profile (not surprisingly.) As a percentage of the total fuel use the standby loss dominates when the use volumes are low. But 36% of a tiny number may never have an economic rationale, since the savings are probably less than the 7% savings indicated in the "typical" water use profile. But you'd get more than a 7% savings by simply dropping the storage temp from 130F to 125F to lower the standby loss.
Similar Threads: Water Heater
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
