Water Heater thumping noise
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by PJ Flocker, Oct 27, 2007.
  1. PJ Flocker
    PJ Flocker New Member
    Oct 27, 2007
    Phoenix, AZ
    I have had my (75 gal, new house) water htr for about 4 years and I have noticed a thumping noise (it is easy for me to hear because it is in the wall right beside my master toilet area) almost every time I use the master shower and when I run the hot water in one of the sinks. It sounds like the noise it is coming right from the hot water heater and not any pipes in the walls. My plumber nor any contractor has been able to figure out what it is. Any thoughts??:confused::rolleyes:
    Thx!! PJ
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Is it gas, oil, or elec...? Does it have and expansion tank on it? Do you have a pressure reducing valve on your main?
  4. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Expanding pipe?
    Hot water running through water or waste pipe causing it to rub on framing members inside the wall - noise is amplified by the drywall surface...
  5. PJ Flocker
    Oct 27, 2007
    Phoenix, AZ
    Yes...sorry it is gas. I don't believe it has an expansion tank...how would I know? And, yes, we have a pressure reducing valve on the main...
    THX
  6. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    If you haven't drained the water heater yearly and it sounds like monkeys drumming whenever there's a quick shutoff of water....it is sediment bouncing around in the bottom of the tank.
  7. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    Agree with Rugged ,Let's call it MUD JUMPING :D drain it with a hose for 5 minutes
  8. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    I don't know what part of the country you're in, but here in Idaho, the water is very hard. Soon after installation, a gas water heater is likely to have a skin of lime on the bottom, and as it heats gas bubbles form under it, and it pops. It can sound like gunfire. It won't do any harm - except for the sound. It's much more prounounced as the heater gets older, and although draining may help, it may not solve the problem. Unless the heater has a hand-hole cleanout, which is a rarity in residential heaters, you're probably stuck with it.
    If your part of the country does not have hard water, it may be, as previously stated, flushable.
  9. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    Thanks' Herk
    Had No idea , Here in N. Ca. We don't have that problem.
    Another VOTE to, " MAKE EM POST THEIR LOCAL. "
    Don't make Me break any more little fingers !! :mad:
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    This may or may not be the solution to the thumping problem, but if you have a pressure regulator valve, then you should install an expansion tank in the cold water supply line. When water heats, it expands and has to go somewhere. A PRV has a check built in that prevents the expanded water from being absorbed by the city main. This causes the pressure inside the water heater to rise rapidly and to a very high level. So high that it usually trips the TP valve on the tank. The expansion tank absorbs the expansed water.
  11. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    Good point Gary,but He didn't mention the t p dumping!
  12. jadnashua
    I thought I'd read that a PRV when it gets worn some can sometimes make that noise under excessive pressure. Regardless, if you have a PRV, you must install an expansion tank...they go hand in glove, you have one, you should always have the other.
  13. hj
    thump
    Do you have a retrofit hot water circulating pump on the hot water outlet of the tank?
  14. PJ Flocker
    Oct 27, 2007
    Phoenix, AZ
    Thanks everybody!!
    Sorry...my location is Phx, AZ. So, as to the re-circ pump..I don't have on of those, although I wish I had one...it takes forever to get hot water to my kitchen. Anyway, I do have hard water where I live in Phx., but I have a soft water system since the house was built...
    Also, it doesn't happen after a quick shut off...usually after the hot water has been running for maybe 5 minutes or so...
    So, I think from all your comments my solution is to flush, check my TPV and the expansion tank...
    Thanks everyone!!!
    PJ ;)
  15. hj
    noise
    The noise could be the water meter sound being amplified by the water heater.
  16. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Hey!
    I'm in Phx and have (maybe) the same issues in TWO houses. Ruud brand 40 gallon.
    No expansion tank, never used them before.
    When I turn on the cold water somewhere, the gas WH occaisionally makes a nice little pop. In the other house it's more of a BANG .
    Mine is not the rumbling sediment sound, just an pop or bang occaisionally
    Must be the heat here.
Similar Threads: Water Heater
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
