Water Heater Tank Question
Discussion in 'Water Heater Forum, Tanks' started by cowboyjosh78, Dec 25, 2010.
  1. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I got that part.
    That is why I wanted eggs to go with my Spam.
    I did not see how this Forum was the best place to post a ad for HVAC.
    Thanks Terry, You are the best.
  2. Wallijonn
    Wallijonn Member
    Jun 7, 2013
    computer technician
    Arizona
    Why isn't the ground wire also connected to the hot water side? If the loop is long enough it shouldn't transfer any heat to the cold pipe.
  3. Terry
    Aug 17, 2004
    Often, the hot and cold are bonded to the panel at the water heater location.
    There is no worry about conducting heat there. It's more to do with grounding.
  4. Wallijonn
    Wallijonn Member
    Jun 7, 2013
    computer technician
    Arizona
    I was thinking along the lines of,
    http://waterheatertimer.org/How-to-wire-water-heater-for-120-Volt.html
    http://waterheatertimer.org/pdf/water_pipe_grounding.pdf
    My problem is that I don't have a separate ground wire going to the cold water line (there's a copper jumper between cold and hot water pipes) and I don't have a lightening rod on the roof. (Most homes in Phoenix don't have them, just as most homes don't have gutters, and most homes have the AC on the roof. Weird, I know...) I figure the ground wire in the conduit wiring is being used to ground it. I hope there's no harm connecting the WH ground screw to the cold water pipe. (I work with electronics and fear ground loops.)
    ibid.
    Gutters and a lightening rod are on the schedule for the future. I have no trees near my house that can attract lightening...
    Now if I can only figure a way to install heat traps since my water pipes are right above the WH, so they go straight down to the WH inlet and outlet... Shark hoses aren't long enough, so I'll have to find flexible copper that is long enough. Heck, my WH doesn't even have an expansion tank...
    And yes, I will be replacing the WH circuit breaker with a new one when I install my WH this weekend.
  5. Wallijonn
    Wallijonn Member
    Jun 7, 2013
    computer technician
    Arizona
    I found out that I do have a ground wire, it's just running along the cold water pipe, so I will be adding a grounding block to the cold water pipe, threading the ground wire through to the hot water grounding block and adding a grounding wire from the cold water grounding block to the WH ground stud.
Similar Threads: Water Heater
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
Water Heater Forum, Tanks Richmond Water heater code 6 problem Feb 3, 2017
