Water heater tank fittings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by wesk, Oct 26, 2008.
  1. wesk
    wesk New Member
    Oct 20, 2008
    I am getting ready to install a new 40 gallon Bradford/White electric water heater tank. It comes with a combo anode-hot water outlet fitting. Both the cold water inlet and hot water outlet fittings (see photo) are "dielectric waterway fittings with 3/4" NPT tapered male threads." There is a plastic lining inside the nipples, white in the hot water outlet and blue in the cold water inlet. Do I leave these plastic linings in place? The reason I ask is because there is also a black membrane across bottom of the plastic linings that looks like it would block the flow of water. Maybe they keep debris from entering the pipes prior to installation and should be removed? Your thoughts?
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Remove them.
    They are just there to tell you which is cold and which is hot and to stop anything from dropping in before installation.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    I diasagree with krow. The "membrane" is a flapper. These are heat-ckeck nipples. Water will only flow IN on the cold side, and OUT on the hot side. The plastic is the dielectric barrier, to keep water from contacting anypart of the galvanized nipples.
    Manufacturers are being constantly "nudged" by uncle sam to up the energy rating, and there is only so much you can do , so they resort to "tricks" like the heat trap to gain a point or two of energy efficiency.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Jimbo has given you the info.. The plastic gives the nipples corrosion resistant properties and that flat is a check valve.
  6. hj
    heater
    And someday if the heater begins to howl or whine when you use the hot water, you will know where those fittings are so you can remove them.
Similar Threads: Water heater
Plumbing Forum, Professional & DIY Advice Hot and Cold PEX Connections to the Water Heater from Below Thursday at 7:14 PM
Plumbing Forum, Professional & DIY Advice Where to place Tankless Water Heater Condensation Line Wednesday at 12:10 AM
Plumbing Forum, Professional & DIY Advice Issue with new water heater Mar 20, 2017
Plumbing Forum, Professional & DIY Advice Getting a tankless water heater installed, but have questions on piping size Mar 6, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet not working after flushing tankless water heater Mar 4, 2017
