Water Heater slow leak from bottom
Timbuktu
PalmSprings SCal
I have a 23 +yo Briggs 42g unit for my cabin which has been in cont' use since at least since 1992. That date was the last time it was inspected by the previous owner,so it could be older.
Without pics, I will set the scene best i can in case thats useful:The unit is in the bathroom corner against an exterior wall. It is enclosed in a little closet made for it.
This enclosure makes it impossible to get past the front of the unit to try and locate the leak.
The rate of the leak is slow enough that Ive been able to place a bath sized towel next to it that becomes saturated after 12-24 hrs and i just switch em out once a day til can get on it.
The wife says" I cant go without hot water, a shower,wash hair"La Bla Bla,you know what I mean.
So my question:
Is it likely ,from my description, it could be fixable enough to give me some time (a week or two or longer until I can get to it?
What do you think?
More towels? Maybe put a piece of plastic under the towels to protect the floor. Turn off the water heater and water to the water heater to get rid of pressure in the tank when you are going out .
Replace as soon as practical.
Timbuktu
PalmSprings SCal
R&R ,ok. Floor is saltillo tile over concrete so i cant imagine an issue unless water gets through grout and undermines the adhesives used under the tiles?? is that likely? The towelss work fine and floor doesnt get wet.
23 years was a good run for that.
When you replace, it's a good idea to take measurements of the space you have.
You will want the height and the diameter of the existing water heater if you want to plug and play with that. Water heaters come in so many sizes.
If it's electric, it may slowly leak. I've seen some gas heaters let go pretty badly.
And just because the water drifts downward doesn't mean the leak is there. It could be anywhere on the tank, including at the top. If water gets to the wiring, it can cause a nice little fire there.
FullySprinklered
Georgia
In 23 years the tank insulation has gotten better (and thicker) on same size water heaters, so if the space is tight make sure to get a good measurement on the space you have to work with. You may have to go taller if it's looking too snug.
Gary Swart
Yakima, WA
The tank has a leak somewhere and it can not be fixed. Tanks have to withstand pressure, and there's no patching that would hold.
If it is in a bathroom, it had BETTER be an electric heater. Once they start leaking, there is NO WAY to fix them. As mentioned heaters have change drastically in the intervening years so you have to measure to see what will fit into the cabinet.
