Water Heater Replacement
Discussion in 'Water Heater Forum, Tanks' started by Clay, Apr 25, 2009.
  1. Clay
    Clay New Member
    Apr 25, 2009
    I have a Duron hot water heater that is 18 years old. Recently I read there had been some problems resulting in a lawsuit. I have had no problems to date with my heater. My concern is should I replace it or will the plastic liner prevent it from rusting thru and developing a leak?
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    From what I read of the settlement that is not the tank issue but with the
    elements.18 yrs is a long time for a W/H.If are not having any problem I
    would not worry to much.But if decide to replace go with Bradford-White.
    BTW my name is Clay:)
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    If it leaks, how much $damage? If none, wait.
    If it dies, how much inconvenience until you get a new one?
Similar Threads: Water Heater
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
