Water Heater Relief Discharge
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Plumbcatastrophe, Feb 17, 2006.
  1. Plumbcatastrophe
    Plumbcatastrophe New Member
    Jan 22, 2006
    Am I okay if my water heater relief discharge goes into a drip pan that can overflow, if needed, to the dirt crawlspace?
  2. prashster
    prashster New Member
    Dec 7, 2005
    novice's opinion
    (not a pro): I think the 'overflow' tube is actually a pressure relief tube. So, if the valve on the top pops, you'll get steam out of there and minimal actual liquid water. Discharging into an overflow pan won't do anything in that case.
    If your water heater develops a leak, it won't be from that tube. I saw someone put their whole water heater into an overflow pan with a moisture-activated alarm and a valve that shut off the cold h2o supply to the heater in the event of a leak. If he hears hear the alarm, he might be able to drain the residual water through the drain valve (at the bottom) b4 the overflow pan is filled. If he doesn't hear the alarm, then at worst he'll get only a tank's worth of water damage.
    Another note: some people say it's good to 'pop' the valve every year to test that it works. Others say not to, because it's a pain to get closed again. Check with someone who knows for sure b4 'testing' it. I haven't havd the guts to try it yet.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'd say it depends on the soil in the crawl space. I install a water heater for my daughter awhile back and set it in a pan. Then while exploring how to best run the drain for the pan, I realized that her house is build on old river bed. So, I just ran the drain into the crawl space because you couldn't saturate that ground if you ran water in it for a month. Unless you have that type of soil, I'd suggest you run the pan overflow to the outside. When a PRV pops, it's just a small stream of water anyway, and if the tank goes south, they will leak but not suddenly fall apart. I suppose a moisture alarm in the pan wouldn't hurt, but I would lose sleep over not have one. Now, if the tank is over finished living space, you certainly will want the overflow to either go outside or into a drain.
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    its OK
    the idea is to keep the water from the pressure valve from
    flooding out your home........
    you will probably NOTICE the water in the pan in either a few minutes or days....
    on average people will notice the water pretty quickly if it is in
    the living area or laundry room....
    you will probably HEAR the water dripping into the pan
    Its a pretty good set up the way it is and
    its far better than the alternative.....of a major flood
    and you really SHOULD NOT just pipe that pop off pipe
    directly into the crawl space the you could really flood the crawl
    indeifintely.......
    I have seen the damage form this.....
    and I was almost on the hook for the water damages it caused
    the hot water from the heater can literally create a STEAM JUNGLE
    affect in the crawl space if it goes on for a few weeks....... and this will
    actually warp your ply-wood floors and the joists .......
    you cant immagine anyone letting this pop off
    for any length of time but it happens... quite often
    if they cant see it happenning
    right before their eyes, or hear the water running
    its usually ignored
    out of sight , out of mind...
  6. Gary Swart
    Sep 1, 2004
    Yakima WA
    My suggestion was not intended to imply that one should allow water to run indefinitely into the crawl space. The overflow from the PRV or leaky tank should be noticed and dealt with within a reasonably short time.
  7. hj
    T&P
    The safety valve is supposed to open at 200 degrees, long before it reaches the steam temperature, so it will be all water.
  8. jimbo
    jimbo Plumber
    Your local code will answer the question. Some areas would not accept the overflow discharging into the drain pan. Some would.
Similar Threads: Water Heater
Plumbing Forum, Professional & DIY Advice New hot water heater/pex. Today at 12:27 PM
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
