Water heater questions; 1 OR 2???
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mporter4, Aug 1, 2008.
  1. Mporter4
    Mporter4 New Member
    Aug 1, 2008
    ATHENS,
    I have an 1800 square foot home with two baths.the master suite has a whirlpool and shower.
    my question is would it be better to have 2 heaters;1 for the master suite and 1 on the opposite end of the home for the kitchen,laundry and bath?
    If so is it cost effient to install a timer to shut-off power for the night time hours?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Sounds like you use a lot of hot water...
    How big is the whirlpool? Gallons?
    Is the shower a single head shower or, a car wash type?
    Standby heat loss is negligable, A timer will yield little if any savings.
  4. hj
    heater
    Water heaters close to the point of use are ALWAYS preferable to those at a distance. Timers do NOTHING to save energy, unless you have peculiar needs or, after heavy use, are willing to go without hot water until the timer turns the heater on.
Similar Threads: Water heater
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Do I need to create more of a electrical break for the hot water heater? Dec 4, 2016
