water heater question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ally68, May 15, 2005.
  1. ally68
    ally68 New Member
    Jan 31, 2005
    Missouri
    I have a softner before my water heater. And I have had mixed opions about the need to drain sediment out of my water heater. Some say yes other plumbers have said it is not worth the trouble as it will not last much longer than 10 years with softned water. Since there is not much sediment anyway.
    I have had to replace about every 10 years due to tank leaks anyway and it is no big deal just wondering if I should bother draining it at all if it will make no difference?
  2. ally68
    ally68 New Member
    Jan 31, 2005
    Missouri
    No one? Also how often should you check the t&p valve once per year?
  4. hj
    drain
    The drain valve on the water heater only flushes the material in its area, so using it to "drain" the heater does not accomplish much since the material is distributed all over the bottom. Even a high volume flush may not remove material remote from the drain opening, and any attempt to remove all the material is very labor intensive. Few people really flush the heaters on a regular basis. Now, the T&P valve should be tested at least once a year and preferably more often, since its operation is vital to the safe performance of the water heater in an unusual situation.
  5. ally68
    ally68 New Member
    Jan 31, 2005
    Missouri
    So in your professional opion considering I have a softner so i should in theory have very little sediment anyway I am really not helping all that much?
Similar Threads: water heater
Plumbing Forum, Professional & DIY Advice New hot water heater/PEX Yesterday at 12:27 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
