water heater problems
Discussion in 'Water Heater Forum, Tanks' started by grizzily, Aug 14, 2010.
  1. grizzily
    grizzily New Member
    Aug 14, 2010
    alabama
    installed a 40 gal. hwh soon after tp valve started to leak intermittently. checked to make sure no trash in valve. problem persisted,changed tp valve same problem. installed an expansion tank. city water pressure is static at 70psi,working at 40 psi set tank pressure at70 psi. line pressure still rises to 150 psi and leaks out of tp valve. need help in solving this problem any suggestions helpful
  2. hj
    Until you know WHY the pressure is going that high, and nothing you have told us indicates what the problem could be, there is no way to diagnose it. BUT, one possibility is that you already have a pressure reducing valve and it has gone bad. That would cause your symptoms even with an expansion tank, and a new T&P valve.
  4. grizzily
    grizzily New Member
    Aug 14, 2010
    alabama
    do not have pressure reducing valve. do I need one for 70 psi static pressure to house? before I changed hwh I replaced 1" galv. water pipe with 1/2" cpvc pipe. galv. pipe was almost closed up with build up. could the change in pipe size cause thew problem
  5. grizzily
    grizzily New Member
    Aug 14, 2010
    alabama
    there is no pressure reducing valve. city water supply is at 70 psi.
Similar Threads: water heater
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Yesterday at 6:41 AM
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
