Water heater pilot light goes out
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Coldnwet, Nov 9, 2008.
  1. Coldnwet
    Coldnwet New Member
    Nov 9, 2008
    I have a Reliance 606 water heater that the pilot light goes out frequently, actually every day. A plumber friend told me that the thermocouple had gone bad, he then proceeded to place a fan in front of the unit and that has worked ever since.
    I really don't want the fan running all of the time, which it must be, and would like to repair the water heater permanently. The unit is not under warranty. Any suggestions?
  2. jimbo
    jimbo Plumber
    Hard to understand how a fan would correct a thermocouple problem. But it might explain a combustion air problem. Is the WH in an enclosed space?
  4. Jay Mpls
    Jay Mpls Master plumber
    Sep 29, 2008
    Master Plumber /Sewer rat
    Minneapolis
    Hire your plumber friend.Fix his(her?) sagging economy and get your water heater done at the same time.
  5. hj
    heater
    If the thermocouple is bad, the heater will not light in the first place, regardless of whether you have a fan there or not. You have a different problem, and if a fan cures it, it could be a combustion venting problem, and that is worse than a bad thermocouple, because it can kill you.
  6. Jay Mpls
    Sep 29, 2008
    Minneapolis
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I think you need a new plumber. Make sure he is a licensed plumber and not just a handyman. As others have noted, gas can really ruin your day.
Similar Threads: Water heater
Plumbing Forum, Professional & DIY Advice New water heater/PEX Sunday at 12:27 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
