water heater options
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 7echo, Sep 16, 2008.
  1. 7echo
    7echo New Member
    Jan 16, 2008
    coastal georgia
    Going to do a remodel and will replace the water heater. I searched and see a lot of positive comments about Bradford White. The Marathon is heavily pushed by the electric company, and they seem like a really good, but expensive, heater. I searched and didn't find many comments on the Marathon. Would appreciate comments/opinions on the Marathon.
    BTW, 2 adults and a 7 yo, probably going with something in the 75 gallon range.
    Thanks
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    get a normal one
    I cant give a Marathon away.....
    they are too expensive and when you can almost buy 3
    normal heaters for the pioce of that one, it does not make sense...
    get a normal Rheem heater and simply put
    a blanket on it...you will probably achiecve about
    the same saveings...
    I am sure that they are a great heater, but remember
    all they do is heat water....
  4. Cass
    Cass Plumber
    Nov 12, 2005
    If you are fairly certain your going to live in the home the rest of your life then it might be worth considering.
  5. hj
    heater
    I assume the Marathon heater is one with a plastic tank. If so, then I have had many "lifetime" heaters where the tank was okay, but the pipe connections to it failed and were not repairable. One customer bought his house because it had a Sears "lifetime" water heater. A couple of months later when it started leaking, he found out that the lifetime guarantee referred to the orignal purchasers time that he owned the tank. Once the house as sold, the warranty was voided. "Lifetime" does not always mean the tank will last forever, but rather,, that they will give you a new heater when it does break, but you have to install it, or pay to have it installed, yourself.
  6. 7echo
    7echo New Member
    Jan 16, 2008
    coastal georgia
    Thanks for the comments.
    I think I will start looking into conventional electric water heaters.
  7. Ian Gills
    Jul 24, 2007
    USA
    Wow they look really nice. But I got a Bradford White plus installation for less than the price of one of those.
    I guess they do not do them in gas, do they?
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  9. Master Plumber Mark
    Feb 6, 2005
    Sears worms out of their warranties
    something else about the sears water heaters and the Marathon "life time warranites"...
    that warranty never transfers on to the next customer...
    it begins and ends with you.....
  10. hj
    Marathon
    If they are plastic as the assembly line photo implies, then they could not be used for a gas water heater. To compensate for that lack they spin the facts to imply that electric heaters operate cheaper than gas models, which may be true in the TVA area, but almost never anywhere else.
Similar Threads: water heater
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Do I need to create more of a electrical break for the hot water heater? Dec 4, 2016
