water heater not working
Discussion in 'Water Heater Forum, Tanks' started by pls49902, Mar 19, 2012.
  1. pls49902
    pls49902 New Member
    Mar 19, 2012
    Florida
    I have an older Ruud 30 gallon electric water heater, model no. RP 30-2 that is not heating the water. There is power to it, but the heater is not working.
  2. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    Make sure you turn the power off to the water heater before conducting the following test.
    Check the elements with a continuity tester with both wires off the element. You should have continuity when probing to each screw at once. If not the element is faulty. If that tests out "ok" remove one probe of the meter and touch it to the bare metal tank. You should not get continuity. Do the same for the second screw terminal on the element. You should not get continuity. If you do the element is faulty.
    Do that for the upper and lower elements.
    Check the high limit reset. Its the red button near the top of the upper thermostat inside the top access cover.
    Make sure the power is off before starting.
    Make sure the thermostats are held tight against the tank. Make sure all your wire connections and screw terminals are tight. Inspect the wiring in general.
    This is no means a complete guide....but its a start for you.
  4. Hackney plumbing
    Jan 6, 2010
    Alabama
    All that said I'm betting its the upper element thats faulty.
  5. pls49902
    pls49902 New Member
    Mar 19, 2012
    Florida
    Thanks for the info.
Similar Threads: water heater
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
