Water heater making strange noise
Discussion in 'Water Heater Forum, Tanks' started by lnjohnson0685, Jul 27, 2011.
  1. lnjohnson0685
    lnjohnson0685 New Member
    Jul 27, 2011
    GA
    2 weeks ago we had a thunderstorm which made me have to press the reset button on my hot water heater. Now it seems like every other day I have to reset it. Well the power went out again yesterday I just now reset it.I turned the breaker off so I wouldn't shock myself... and when I flipped the breaker back on it made a strange noise, it sounds like a current is running through the heater... like you can actually hear the electricity running through the wires. Should I be worried is it safe? The insulation felt alittle wet to me also.
  2. hj
    You had to press the reset button every other day, because the water was "super hot" due to one of the elements being shorted out. the sound you hear is probably that element "boiling water".
  4. lnjohnson0685
    Jul 27, 2011
    GA
    so what should I do? I mean it sounds like electricity not boiling water. And should I turn down the temperature?
  5. supreme
    supreme New Member
    Jul 27, 2011
    miami,fl 33147
    Hi,what brand is your tankless water heater?
  6. lnjohnson0685
    Jul 27, 2011
    GA
    it says STATE water heater-- Censible energy effiency the maintance guy is coming sometime tomorrow but thought i could fix it myself
  7. hj
    It needs at least one new element, and since it is electricity, you probably should NOT try to fix it yourself.
  8. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    So what did the maintenance guy do yesterday?:confused:
  9. lnjohnson0685
    Jul 27, 2011
    GA
    he hasn't showed up yet i will let you guys know if im here when he comes
Similar Threads: Water heater
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Saturday at 6:41 AM
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
