Water Heater Location Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by PlumbBobSquarePants, Oct 22, 2007.
  1. PlumbBobSquarePants
    PlumbBobSquarePants New Member
    Dec 10, 2006
    Is there any reason why I can't have my new water heater installed as per the picture attached? Where the dryer currently is.
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    It appears that you have two fired units going into one flue. That is usually an unacceptble situation, whether the heater is where it is or where you want to put it.
  4. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    It looks like that will be ok.
  5. PlumbBobSquarePants
    Dec 10, 2006
    I sure hope it is acceptable as the new flue liner is only 18 months old? It was a reputable company that installed all of the new venting. Didn't need a water heater at the time.
  6. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    If you posted the state/city/town etc... you live in it would be a lot simpler to tell you what is in code for you.
  7. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    See Folks
    THIS IS WHAT I WAS TALKING ABOUT !!!!! Thank's Pat :)
  8. dowop
    dowop New Member
    May 19, 2005
    I'm not so sure about this..... It is done all over the place (and legal) in the Northeast. A rough calculation is that the flue is sized for the largest diameter gas fired flue + 50% of the second size. For the acutal calculation you can reference one of the B-Vent companies product specifications (you need to know the BTU of each appliance). www.hartandcooley.com or www.mtlfab.com
    Check with your township, state, but here as long as your using the right size for total BTU you would be allowed to combine them.
  9. hj
    heater
    The only time it would not work is if either of the units had a powered flue. Then the forced draft one would backdraft into the other one.
  10. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    In N. Ca. ,older homes have this same set up all over , no problem.
    This is a prime example why D I Y should list their state and city.
    We promise not to tell any x wives out there,REALLY
Similar Threads: Water Heater
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Yesterday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
