Water heater leaks.
Discussion in 'Water Heater Forum, Tanks' started by kingnus, Apr 25, 2009.
  1. kingnus
    kingnus New Member
    Dec 21, 2007
    I have a water heater that leaks once a day from around the bottom. It leaks maybe 1/4 of a cup.
    I can not see where it is coming from. Anyone have an ideas?
    Charles
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    If you have determined that it is not coming from any other source above. (T&P connection, hot/cold connections etc.) then it may be the tank rusting out. How old and one kind of WH is this¿
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There are only 4 pipe connections water where water could be coming from that one might be able to repair: Intake, outlet, T/P valve, and the drain valve. Any place else, and it is a hole(s) in the tank, and it's game time.
  5. kingnus
    kingnus New Member
    Dec 21, 2007
    water heater
    Water heater is a Rheem and 9 years old. Thing I do not under stand is why it on leaks once in a while. NOt leaking from any of the valves . I put a container under the valves so I know it is not leaking there.
    Charles
  6. Cass
    Cass Plumber
    Nov 12, 2005
    The leaking hole is sealing up until there is enough pressure to cause it to leak again...it will eventualy start leaking and not stop...
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    Do you have a pressure regulator valve on the main supply line and if so, do you have an thermal expansion tank? If you have a PRV and do not have an expansion tank or if you have a tank, the bladder could be shot. This would cause the T/P valve to open when the pressure get too high in the water heater. The T/P closes when the pressure is relieved and is no longer building up so the leak would be intermittent.
  8. kingnus
    kingnus New Member
    Dec 21, 2007
    water heater
    thanks all, I guess it is time for a new one.
    Charles
  9. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Maybe...
    But is it is the T&P valve that is leaking a new water heater will leak as well.
Similar Threads: Water heater
Water Heater Forum, Tanks Water heater has no drain pan, what precautions should I take? Mar 6, 2017
Water Heater Forum, Tanks Hot Water Heater Flame Temperature Mar 4, 2017
Water Heater Forum, Tanks Whirlpool 10 year old Water Heater Mar 4, 2017
Water Heater Forum, Tanks Gas Water Heater Explosion? Mar 4, 2017
Water Heater Forum, Tanks Water heater not always firing Mar 4, 2017
