Water Heater Inspection - Drain Valve Angle Question
Discussion in 'Water Heater Forum, Tanks' started by luckycharmz336, Jul 23, 2010.
  1. luckycharmz336
    luckycharmz336 New Member
    Jul 23, 2010
    AZ
    The water heater drain valve angles about 2 inches up hill from the water heater to the wall, the inspector said this is an issue and safety hazard. How concerned should we be able this? Below is a picture [​IMG]
    We want to have it fixed if it is a major issue, however, if we shouldn't be concerned I don't want to force them to change it. Thanks
  2. Terry
    Aug 17, 2004
    Cut the wall and lower the 90 in the wall.
    Below is my favorite exploding water heater video.
    In the Seattle area, a water heater shot though a garage roof and landed blocks away.
    [video=youtube;GF_Wrm-Ns0I]http://www.youtube.com/watch?v=GF_Wrm-Ns0I[/video]
  4. 3m
    3m New Member
    Mar 3, 2009
    NY
    where is the line going to
  5. jimbo
    jimbo Plumber
    It is a fairly serious problem. Almost guaranteed that as time goes by, some drippage will occur from the valve, or some condensation will occur in the line. This water will sit right there at the relief and leave mineral deposits, clogging the valve. It might not work when it needs to.
    Somewhat shocking that it is done this way.....obviously no permit because the inspector would still be looking for a big enough crayon to write NO WAY.....all over the papers!
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It is a definite FAIL...
    It will cause the reliability of the T&P valve to suffer and could result in a hazardous condition....
  7. hj
    The easiest way to correct it is to place some concrete blocks, or a few circular concrete stepstones, under the heater to raise the valve above the opening in the wall. That corrugated connector is also "illegal" in most areas. Use copper tubing to connect the SAFETY valve, (not a DRAIN valve), to the pipe at the wall. In Phoenix, the heater landed a block away, and the house had to be demolished because it was not repairable.
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Sorry to see that you have a Whirlpool Energy Smart water heater as well....
Similar Threads: Water Heater
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Today at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
