3 licensed plumbers later . . .
40 gal natural gas water heater. The heating part is working fine, when the water's cold enough the burner kicks on and heats it.
But! For no reason I can find, the hot water pressure fades away to zero at all the faucets in the house. This has happened several times. Then it comes back full force and works fine for a day or so.
Pressure on the cold water side of the faucets is always fine.
Cold water to the house comes in right at the water heater and spilts. Since the cold water pressure never drops I assume any filling/pressure problems on this side are inside the tank.
Hot water goes out and immediately splits in several directions. Since faucets in all directions stop getting hot water, I again assume an out-flow problem is inside the tank.
Tank has been drained and refilled. Very little sediment or anything except clear hot water came out. Burner kicked on fine and heated the fresh tank of water.
The standard answer I'm getting is "we'll gladly replace your water heater but no guarantee it will solve anything".
I don't think they know what goes on inside a water heater and neither do I.
Anybody?
Anybody?
