water heater "heat loops"
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by edwardh4, Dec 17, 2008.
  1. edwardh4
    edwardh4 New Member
    Dec 17, 2008
    South Carolina
    If my water heater has heat loops (piping "u" to stop heat loss) on the supply and output lines, and I then insulate these lines, will the insulation cause the heat loops to not work?
  2. Probedude
    Probedude New Member
    Nov 25, 2008
    CA
    Good question - they'll still work AND you'll save some energy since you'll slow the heat dissipation from the loops to the ambient air.
  4. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Insulation is added protection.
Similar Threads: water heater
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
