water heater flex question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tom-rad, Nov 3, 2009.
  1. tom-rad
    tom-rad Member
    Sep 2, 2007
    Maryland
    I installed 12" ss braided flex lines on my water heater, and the directions say 'hand tight plus 1/4 turn'. I wrapped my fist around the fitting, and turned by hand until they stopped. No leaks, but should I do the extra 1/4 turn w/wrench? Don't want to distort the rubber washer too much, or damage the thread (it's 3/4"npt), but I also don't want it to be too loose and leak as the rubber gasket ages. Thanks, I apologize if this is a dumb question, but I don't work with this stuff all the time, and I am not sure. Thanks again.:D
  2. hj
    connections
    My rule is to tighten them as tight as they will go, NOT just a 1/4 turn past hand tight. How do THEY know how tight YOU can turn them by hand?
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Agree with hj on this...I have always tightened them down...not the 1/4 turn past hand tight...I used to argue with another plumber about that until he flooded a home and had an Ins. claim...funny he didn't argue with me any more...
Similar Threads: water heater
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Do I need to create more of a electrical break for the hot water heater? Dec 4, 2016
