water heater drain
Discussion in 'Water Heater Forum, Tanks' started by netmouse, Oct 9, 2013.
  1. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    I am having an electric water heater installed in my basement that has a concrete floor, unfinished. There was none here before.
    There is no floor drain. There is one drain pipe about 4 feet off the floor that drains downward to the sewer pipe a few feet below that. A rubber hose from my washing machine empties into that (the pipe sticks up and is open on top, and the washing machine rubber hose folds over and into that). What can be done for a new electric water heater? Does code typically require a floor drain or submersible sump pump that drains up and out to the ground or into that drain / sewer pipe or ..... is that something not in code and not what is looked at?
  2. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    I am reading about a taco wags shut off. And a A.O. Smith shut off. Is this the solution I need? If this shuts off new water entry and the tank still empties, is there a hazard by having the electric elements sill on with an empty tank (I assume it'll maybe kill the elements, but hopefully not burn the house down)?
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
Similar Threads: water heater
Water Heater Forum, Tanks reducing 2 hot water heaters to 1. 54 minutes ago
Water Heater Forum, Tanks Water heater has no drain pan, what precautions should I take? Mar 6, 2017
Water Heater Forum, Tanks Hot Water Heater Flame Temperature Mar 4, 2017
Water Heater Forum, Tanks Whirlpool 10 year old Water Heater Mar 4, 2017
Water Heater Forum, Tanks Gas Water Heater Explosion? Mar 4, 2017
