Water heater drain pan
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Xenomorph, Jan 14, 2007.
  1. Xenomorph
    Xenomorph New Member
    Jul 10, 2006
    I am just wondering what you guys do to connect the vertical tailpiece/downspout to the galvanized water heater drain pan. The tailpiece is brass, but the pan is galvanized. Is it possible to solder the 2 together using acid flux and regular solder?
    thx.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    The T&P is 3/4 threaded brass that will accept a copper male adp. with soldered pipe going to a upright T with a 3" X 1.5" coupling bushed reduced down to 1" into the T. It needs a 2" air gap between 3" PVC and the copper. This is what is required where I am. They don't want the T&P going into the pan incase the T&P leaks the heater would be sitting in water.
  4. Plumb or Die
    Plumb or Die Plumbing Instructor
    Jan 13, 2007
    Plumbing Instructor
    Southern BC Canada
    Yes, you can
    Yes you can solder it, just heat slowly to not overheat and blacken the galvanized pan. A always solder them, a buddy of mine silicones his.
  5. Xenomorph
    Jul 10, 2006
    Thx for the ideas Plumb or Die :)
Similar Threads: Water heater
Plumbing Forum, Professional & DIY Advice New hot water heater/PEX Yesterday at 12:27 PM
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
