brmiller
I intend to move my hot water heater from inside a closet in the habitable area of my basement to a garage closet that also houses the air exchanger/furnace and ejector pump for the basement bathroom. This closet is part of the garage that was closed up to hide the mechanical.
In my permit application, the county plan engineer (Clark Co, WA) marked that the new water heater had to be 24" from the ejector pump. I didn't notice when I was in the permit office, and when I got home and measured the distance from the ejector pump well to the opposite wall where I intended to put the water heater and I only have 37". No water heater is that small to still allow a 24" margin, so according to the notes on my plan, this won't work. Sure, I can call the plan engineer, but I'm curious (on a Friday night) what the rationale is or if someone can point to the code that informs this distance requirement. I know when we had the furnace replaced, planning for this water heater move, the HVAC installer was careful to set it up so there would be the minimum required space for maintenance in front of both furnace and future water heater. Is this the distance requirement? Some kind of 24" space on both sides of the water heater (water heater would be in a corner)?
Thanks in advance - my first post here and I've learned a lot about DIY plumbing already.
Brendan
Brendan
