Water Heater Dip Tube
Discussion in 'Water Heater Forum, Tanks' started by Cass, Feb 27, 2009.
  1. Cass
    Cass Plumber
    Nov 12, 2005
    I was working on a 80 gallon Craftmaster Electric heater with a disintegrated dip tube. The nipple crushed when I removed it and the nipple and dip tube were one piece, does anyone know if anyone sells dip tubes with nipples attached? I attempted to put in a regular dip tube but it just falls into the tank their is no shoulder for it. Any ideas?
    Thanks.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Craftmaster is made by AO Smith. might need to check a dealer.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I seem to recall seeing dip tubes that had some kind of fitting on top when I was getting one for my heater a couple of years ago. Sorry I really can't be very specific, but it makes me thing that there are some different kinds around. Maybe you could just use some duct tape.:p
  5. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Screw in a dielectric nipple with a dielectric female union OR use a dielectric male union and insert one of those blue replacement dip tubes through the dielectric union.
    That flange part will keep from sliding down into the tank, along with keeping corrosion from closing up the male or female dielectric fitting.
    Works like a charm.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Thanks....I don't keep them on the truck because all I use are Dia. Nips and coper female adaptors....
    I'll try that today...
  7. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    bradford white
    get a bradford white dip tube with
    the 3/4 threaded galv nipple atached
  8. hj
    tube
    Put a close nipple into the tank and then drop the tube through it.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    I used a 3" nip with a FIP dialetric coupling attatched...I pushed the dip tube through the lower 1/2...very tight...had little wispy curls of PVC come off but it worked...and installed the gasget...perfect fit...then put it together...
    Thanks RUGGED.....It does work like a charm...
  10. dmax56
    dmax56 Handyman
    Sep 19, 2007
    handyman
    NJ
    Dip tubes online
    Cas,
    I just replaced my diptube and got one from Waterheaterrescue.com
    The curved diptube I got had close nipple attached...so did combo, flexible, mag anode they sold...since I didn't have separate anode on my brad-white heater.
    Hope that helps...sure they can get something overnight to you...very helpful there!
    Doug
Similar Threads: Water Heater
Water Heater Forum, Tanks Reducing 2 hot water heaters to 1. Monday at 2:01 PM
Water Heater Forum, Tanks Water heater has no drain pan, what precautions should I take? Mar 6, 2017
Water Heater Forum, Tanks Hot Water Heater Flame Temperature Mar 4, 2017
Water Heater Forum, Tanks Whirlpool 10 year old Water Heater Mar 4, 2017
Water Heater Forum, Tanks Gas Water Heater Explosion? Mar 4, 2017
