Water heater copper pipe corrosion
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ralfonso, May 6, 2008.
  1. ralfonso
    ralfonso New Member
    May 6, 2008
    I've found a few threads with similar photos, but the answer seems to be different in cases that look the same to me. I'm a complete plumbing novice.
    Can anyone tell me what would cause this corrosion? The installer insists that it was properly installed (though he won't send someone out to check) and claims that it's a leak. (that mysteriously appeared after the install because the pipes were fine with the old water heater)
    [​IMG]
    [​IMG]
    [​IMG]
    Larger versions:
    http://steelbreeze.org/misc/heater/union.jpg
    http://steelbreeze.org/misc/heater/upper.jpg
    http://steelbreeze.org/misc/heater/both.jpg
  2. Ian Gills
    Jul 24, 2007
    USA
    Ignore me, because I am not an expert, and I am sure experts will chime in later.
    I do not like the look of that saddle valve above your shut-off valve. That looks as though it is/was leaking.
    And while your electrician was right to jumper your water heater (with the copper wire) the clamps he used do not appear to be copper or brass or bronze. If they are steel they will react with the copper pipe.
    And I wonder if your dielectric union on the cold supply became faulty?
    And where is that flue going? (unrelated to your problem). Is it allowed to do that someone? And it should be screwed to the vent hood.
    Your pics should generate a lot of responses.
  4. ralfonso
    ralfonso New Member
    May 6, 2008
    The plumber did install the jumper. I have no idea where the flue goes :/ I think he might have installed that valve also.
  5. Ian Gills
    Jul 24, 2007
    USA
    He surely did not install the small corroded valve above the blue valve and the jumper because it does not appear to be connected to anything. Let's wait for the pros.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    You should give the local plumbing inspector a call. It is not a saddle valve leak those are ground wires. The leak is in the joint that the plumber did not solder correctly and the water heater may be corroded very badly because of it... This Bozo needs to come back and fix his pig slop plumbing!
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Gosh, Redwood! Do you have to be so diplomatic? Can't you just come out with it and tell it like it is? Geezh, I had pussyfooting around! :p
  8. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    From all the corrosion I am going to guess moisture and condensing.
    1. I am guessing that it's the cold line going to the hot water heater.
    2. it's in an area that has moisture or a leak.
    I would use some white vinegar or LCR cleaner to clean all the pipes.
    Then coat all the pipes in something to keep the whole area from rusting
    like Oil, grease, petroleum jelly, tape, or paint.
    It's hard to tell where to start until it's cleaned. Once cleaned it will be easier to see where the corrosion starts again.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    I see the whole problem as a leaking joint at the 3/4 X 1/2 coupling. If its fixed right away that water heater may last! Its well on its way to being junk! Nothing to do with condensation! I was wrong there is a saddle valve above the ground clamp but its not the problem see how every thing above the reducer is clean with no corrosion. While doing the install he should have gotten rid of the saddle valve... Just laziness is all I see.
    I would not only go back to check my work but if it looked that bad I would do some major sucking up!
    Sorry I'm no diplomat! Can you tell!:cool:
  10. Cass
    Cass Plumber
    Nov 12, 2005
    The saddle valve is leaking...possibly due to a slow leak and the steel bracket and copper contacting each other causing the problem. The 1/2 X 3/4 coupling appears to be leaking also. There may be other problems that show up / are found after this is corrected and cleaned up.
    There appears to be a T where there once may have been an expansion tank...do you have a check valve and or pressure reducing valve on the system?
  11. Ian Gills
    Jul 24, 2007
    USA
    Are water heater flues allowed to join furnace flues like that?
    It's a neat solution if they are, but it looks too simple to me. Surely if both devices are working this could risk CO escaping from the WH?
    Comments please.
  12. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    I agree with redwood. It looks like you have a leak at the 1/2 x 3/4 " coupling. although the saddle valve looks pretty bad too. I would cut the pipe just about the saddle valve and install a 1/2" x 3/4" coupling and then a ball valve then remove the union and redo it. How long ago was that water heater installed?
  13. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    Oh, yea, and it doesn't look like the plumber put screws in the flue pipe to connect it to the hood.
  14. Redwood
    Dec 15, 2007
    Service Plumber
    And it looks like that might be a black iron plug in that tee too.
    Mighty ugly install any way about it!
    Everytime I look at it the thing looks uglier!
Similar Threads: Water heater
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Do I need to create more of a electrical break for the hot water heater? Dec 4, 2016
