Water Heater Connectors Leaking
Discussion in 'Water Heater Forum, Tanks' started by jasonbaur, Nov 15, 2010.
  1. jasonbaur
    jasonbaur New Member
    Nov 15, 2010
    California
    Hello, I recently installed a Rheem 50 gallon gas water heater , I used the existing copper connectors but replaced the plastic o rings/seals & Teflon tape on the threads however I am getting small droplets every 30-40 minutes sometimes longer when no water is been used within the house. I have them about as tight as they will go so I'm thinking of replacing the pipes but I have no idea how to bend them the the way they are currently. The shut off valve to the house is also leaking its the circular turn knob type, I was wondering if there's a way to fix that or does it have to be replaced. I have posted a link below with some pictures, any advice or suggestions would be appreciated
    Thanks
    http://img607.imageshack.us/slideshow/webplayer.php?id=photo111310001u.jpg
  2. Terry
    Aug 17, 2004
    Remove all of the Teflon Tape for starters.
    And then either replace the rubber seals, or throw out the old flexes and start over.
    We always throw out the old flex and use new ones. Or guess what, you have dripping flex connections. Just not worth rusting the top of your tank for what the flexes cost.
    Teflon Tape interferes with the seal. It has to go.
  4. jadnashua
    On the shutoff, if you tighten the packing nut slightly, you can probably stop it from leaking around the stem. This is the nut the stem fits through under the handle. You often don't need much rotation to stop a drip, and if you get it too tight, you won't be able to turn the handle.
  5. hj
    Tighten the nut on the valve. The one leaking at the pipe on the hot side, usually means the end of the galvanized nipple is rusted and too rough to seal properly. The one on the cold which is leaking at the top of the nut, usually means the connector itself is bad and has to be replaced. You do NOT have any "difficult" bends to make as long as you get new supply lines the same length as the ones you have now. However, we NEVER reuse the supply lines when we replace heaters, especially when they are "nut by nut" ones which are not soldered in.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm not a plumber, but where I am at least, plumber always install new copper flex when installing a new water heater. If it was my project, I replace the flex. The only thing you have to be careful about in bending them to shape is to use gentle bends.
  7. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    The problem is more than likely the galvanized nipples being coroded, but I would replace the flex lines as well anyway with braided lines. Copper and galvanized shouldn't be directly connected as they cause corrosion. Switching to the braided lines and replacing the short nipples should solve the problem.
  8. jasonbaur
    Nov 15, 2010
    California
    I do want to replace those supply lines but for the life of me when I tried bending the new supply lines the copper kinked horribly and closed the passage way. I bought this exact pipe link below. I tried bending it ever so gently and even used objects that were circuluar to help assist but with no luck, and I did purchase some flex line ones but they werent flexible enough and also kinked, all I can think of is those lines were bent after they were heated maybe with a propane torch and bent into shape as there not to flexible anymore.
  9. jasonbaur
    Nov 15, 2010
    California
    When you say braided you mean like this (picture below) I purhcased this kit and tried to use them but they would kink also when doing the bends I need.
  10. Terry
    Aug 17, 2004
    use the copper flex, connect one end first, then holding onto the end, the part with the nut, pull it over to the pipe on the heater. It will naturally bend easier that way and without kinking. There, I just gave away a plumbers secret again.
  11. jasonbaur
    Nov 15, 2010
    California
    Thanks for the tip I did try this maybe I just purchased a bad brand (watts) with some cheap copper or something.
    Here are some pictures I took of the supply lines I bought and tried to use with no luck.
    http://img691.imageshack.us/slideshow/webplayer.php?id=60910712.jpg
    [​IMG]
  12. Terry
    Aug 17, 2004
    The more copper is bent, the stiffer it gets. You really only have one shot at it.
  13. jasonbaur
    Nov 15, 2010
    California
    Gotcha, ok well I will purchase new lines tomorrow (different brand) and try again.
    Sigh I have another problem I think, my wife was cleaning out the trash cans under the sink in the bathroom and she noticed water and well sure enough now that's leaking. To make a long story short I think I know why this happened I think it all comes down to a bad water pressure regulator valve.
    (back story)
    I replaced a toilet with a pressure assist system maybe 2 months ago and I decided that the water pressure (50psi) was to low so I raised it after watching a few videos how to (80psi) after a few weeks washing machine overflowed it couldn't stop itself i figured **** I better lower that back down so I went to (65psi) well the damage had already been done the next day I saw my water heater had started to leak from the tank itself on the bottom so I replaced it with the new one you see now. And now sure enough I tested the water pressure and it starts at (65psi) just like I set it from last time but it slowly climbs after around 15-20 minutes it raises to around (75psi) so I figure the regulator is bad and needs to be changed. How hard of a job is that to do with galvanized pipes would I need any special tools etc? Here is a picture of the current regulator below.
  14. Terry
    Aug 17, 2004
    If you have the PRV, then the water heater needs an expansion tank.
    Though, if the PRV is older then ten years, it could need a rebuild or replacement. I would add the expansion tank first, and then see how it is working. Right now, everytime the water is heated, it's raising the water pressure.
  15. jasonbaur
    Nov 15, 2010
    California
    Ah, hmm well I am not sure if this matters but I had tested the pressure from a valve after the pressure regulator, so I would think no matter how much pressure is pushing through (130psi from the street) the regulator would handle it, its rated to (300psi) on the label. I think its from 1989 when our first water heater blew up because we didn't have a regulator I think sears installed that one. Concerning the expansion tank is that really needed? I am only using the water heater at 120 degrees default by all standards I had read but not certain. The PRV is the pressure relief valve? shouldn't that release some water if there is to much pressure/heat, as of yet it hasn't.
    Just trying to understand how this all works I am very new at this been reading as much as I can.
  16. jadnashua
    A PRV acts like a one-way valve. WHen you use a lot of hot water, then heat it, it expands. This will raise the internal house water pressure until you use a little, or it leaks out because of the higher pressure. A closed system like yours needs an expansion tank or you are stressing things. The Watts site has a calculator to determine the size needed. It uses the incoming water temp, the tank setting, and the size, along with how many feet of pipe.
  17. Gary Swart
    Sep 1, 2004
    Yakima WA
    The usual result of heating water with a PRV but without an expansion tank is the T/P valve on the tank will open and release the excess pressure. That's what it is supposed to do to keep the water heater from blowing up. Literally and big time blow up. So yes, you need an expansion tank.
  18. jasonbaur
    Nov 15, 2010
    California
    Ah, thank you for explaining that in depth now I think I understand I went and touched the copper and sure enough the cold water line was warm to the touch and after I released some hot water from the pressure relief valve (T/P valve? I don't know these acronyms yet), immediately after the copper was cool to the touch so I see how its causing pressure build up to my house line.
    Also thank you Gary for your info, and as I said before the T/P valve has not released any water on its own but I read on another post it takes 150 degrees I think it was your post actually so I understand now why it hasn't released.
    Expansion tank here i come :( , for now should I lower the water pressure to around 50psi or just leave it I'm worried I don't want my new heater to blow up.
  19. Jerome2877
    Aug 25, 2009
    Its a Pressure Reducing Valve, not Relief two different things. How about just scrap the flex lines and use some copper and fittings.
    A T&P valve is normally set to release at 150 psi or 210 degrees F.
  20. jasonbaur
    Nov 15, 2010
    California
    Hey, oh ok well I wasnt sure I have been looking up these acrynoms as you guys use them, http://en.wikipedia.org/wiki/Pressure_relief_valve
    "A pressure relief valve is a safety device that relieves overpressure in a vessel or piping. "
    http://en.wikipedia.org/wiki/Pressure_regulator
    "A pressure regulator is a valve that automatically cuts off the flow of a liquid or gas at a certain pressure"
    I also see Water pressure reduction but there's no info just shows the name.
    Thanks and I think I am using copper lines and been trying to use new copper lines so im not sure what youre reffering to.
  21. Terry
    Aug 17, 2004
    Jerome,
    He's in California. It has to be flex because he's in earthquake country. That's why I like to know where you guys are. It makes a difference as to how the question is answered.
Similar Threads: Water Heater
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
Water Heater Forum, Tanks Richmond Water heater code 6 problem Feb 3, 2017
