Water Hammer Just Started
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by brantdavis, Aug 9, 2006.
  1. brantdavis
    brantdavis New Member
    Aug 9, 2006
    I live in a triple-decker condo built around 1909. The third floor condo just replaced their entire bathroom. While it may just be a coincidence, the pipes feeding their unit have had a LOT of water hammering since the work was done. This is especially true with the hot water where the noise is especially loud at the water heater (I live on the first floor and am the one who gets the brunt of the noise at 5 a.m.!!). Any thoughts on how to fix this? And why would it start just after the construction? Thanks...
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Talk to the people on the third floor and ask them to check it out.
    Could be just a loose washer in a shut-off valve associated with their unit.
  4. brantdavis
    Aug 9, 2006
    This is just puzzling us... The plumber who did the work is talking about a need for water hammer arrestors. This seems completely unnecessary since there was NO problem before the work was done. Also, the shut-off valves + the water heater are in the basement (the bath renovation was on the 3rd floor). No work was done on the shut-off valve or any plumbing in the basement.
    Thoughts on what on the 3rd floor would have caused this change?
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    You may have a valve that chatters and instead of an air hammer.
    A chatter is when the washer in the valve is loose or is warn thin around the edges.
    There may be supply stops at the fixtures in your bathroom that the contractor used . Try closing those stops and then open them up all the way.
Similar Threads: Water Hammer
Plumbing Forum, Professional & DIY Advice Why Now Water Hammer? Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Water Hammer problem Jan 12, 2017
Plumbing Forum, Professional & DIY Advice Banging noise from copper hot water pipe (not water hammer) Dec 19, 2016
Plumbing Forum, Professional & DIY Advice Banging/Knocking sound when tenants flush. Water Hammer Arrestors have been installed. HELP Please! Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Water hammer after servicing a pressure balancing single handle shower valve Nov 15, 2016
