Water hammer arrestor leak
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ktvaughan, Mar 25, 2012.
  1. ktvaughan
    ktvaughan New Member
    Aug 29, 2010
    Northern Indiana
    I have a water hammer arrestor PVC column that is leaking (cracked PVC pipe).
    It has an elbow off the main water inlet with a nut that threads into the elbow.
    Can I unthread that nut and replace the column or would it all be glued together?
    What is the current recommendation for replacing this (it's a simple 18 inch long piece of 3 inch PVC pipe capped at the top)?
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    It should all be glued together! I don't know why it's even on the system if you have a pressure tank? Replace it with new and you should be OK.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Must be pretty bad water hammer if it cracked the arrestor. Need to find out what is causing the water hammer and fix that. Water hammer is the symptom, you need to find and prevent the disease.
  5. ktvaughan
    Aug 29, 2010
    Northern Indiana
    I replaced the PVC air column but the system stills hammers when the well pump shuts off. Pressure, cycling and pump seem to be working normally. It just hammers when the pumps shuts off at the end of a pump cycle. What would this a symptom of? Maybe my air column is too tall (I added 18 inches to be safe).
  6. ktvaughan
    Aug 29, 2010
    Northern Indiana
    I immobilized the air column with a 2x4 and it seems better. Maybe the air column was vibrating when the pump cycled.
  7. valveman
    Mar 15, 2006
    Lubbock, Texas
    You probably have a check valve with the spring broken or the check valve is dragging. When the pump shuts off, the spring is supposed to close the check before the water direction reverses. If the spring is broken, the check only closes after the water reverses which causes a water hammer.
Similar Threads: Water hammer
Pumps and Tanks Well Forum & Blog. Water is life. Water Hammer with Well Pump Apr 5, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Water Hammer Nov 17, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well Water Hammer Aug 18, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Another Water Hammer Question Jul 10, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Water hammer while well is pumping Jun 18, 2014
