Water Hammer Arrester - Must be Vertical?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by larrymcg, Sep 28, 2010.
  1. larrymcg
    larrymcg Member
    Dec 28, 2009
    Silicon Valley
    I'm guessing this is a silly question, but..... Does the tube of a water arrester have to be vertical?
    Since the arrester tube has a piston that separates the water from the contained gas, I thought there could be a chance that the tube could be horizontal.
    I want to put arresters on the hot and cold lines to the clothes washer but the current flexible lines connect to shut-off valves with outlets that go straight down. So connecting something like the Sioux Chief Min-Restor at the shut-off valves would have the tube in the horizontal direction.
    --Larry
  2. Terry
    Aug 17, 2004
    They can be horizontal.
    However, you can also mount them on the washer and keep them vertical is you want.
  4. larrymcg
    larrymcg Member
    Dec 28, 2009
    Silicon Valley
    I wonder why I didn't think of mounting them on the washer? The connections on the washer are above each other so I could mount the top arrester vertically and the bottom one at a slight angle to miss the top one!
    Thanks,
    Larry
  5. jadnashua
    Ideally, the arrester is installed as close to the quick-acting valve as possible...and, with an engineered on, orientation is irrelelvant.
  6. hj
    Point the top one up and the lower one down. They will work effectively in either direction.
Similar Threads: Water Hammer
Plumbing Forum, Professional & DIY Advice Why Now Water Hammer? Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Water Hammer problem Jan 12, 2017
Plumbing Forum, Professional & DIY Advice Banging noise from copper hot water pipe (not water hammer) Dec 19, 2016
Plumbing Forum, Professional & DIY Advice Banging/Knocking sound when tenants flush. Water Hammer Arrestors have been installed. HELP Please! Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Water hammer after servicing a pressure balancing single handle shower valve Nov 15, 2016
