Water gurgling right at drain new sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by PGragg, Sep 17, 2011.
  1. PGragg
    PGragg New Member
    Sep 17, 2011
    falls church, VA
    Just put in new vanity and vessel sink. Contractor had to reconfigure piping under sink with PVC. Sink came with pop-up stopper and tail piece. Loud water noise right below sink hole of water running through and some as it runs down PVC pipe to p trap. How do I fix it? It's loud and annoying but appears to be related to materials not any venting problems. Not a burgling, bubbling gurgle just trickling sounds.
  2. hj
    quote; Loud water noise right below sink hole of water running through and some as it runs down PVC pipe to p trap.
    I have no idea what that means. What is the "sink hole" and is it running down the outside of the PVC pipe? Is the trap under the sink drain or off to the side?
  4. Terry
    Aug 17, 2004
    If it's draining quckly, then there will be more noise.
    Some lav drains are so gooed up, that they no longer drain quckly.
    Can you post a picture?
    800 pixels or less.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    If the popup is adjustable, set it so it doesn't open as wide and it will drain slower. Why did the contractor have to use PVC? Metal would be more quiet.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I think I would call the contractor back. Was this a plumbing contractor?
  7. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    I also installed a vessel sink with a pop up stopper. The sink has no overflow hole, which a normal lav sink has, and water going down the drain pulls air down with it, air maybe that a normal sink with overflow would aid the water going down the tail piece quietly. My DIY 2 cents homeowners opinion. the noise never bothered me though, but it does exist. think of it as sounds of tranquility
  8. PGragg
    PGragg New Member
    Sep 17, 2011
    falls church, VA
    Thanks everyone for your comments. If you see another thread on this, sorry. I couldn't find my original thread. My husband thinks the noise is loud because the contractor immediately stepped up the pipe size to 2" PVC. My husband thinks the piece under the tailpiece should be the same size and metal and go a little ways and then step up to the bigger pipe size. That's what the other sinks in my house have if they have to run a long ways down to mee the p trap. What do you all think?
  9. hj
    Not likely, but since we cannot hear the gurgling, (and "gurgling" can mean many things and have many causes), or see HOW he configured the drain line, (it is NOT likely to be 2" however), we cannot diagnose, or even comment, on it.
  10. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    A picture is worth a thousand words.
    I would terminate the PVC at the wall and go with an all metal trap and tailpiece.
Similar Threads: Water gurgling
Plumbing Forum, Professional & DIY Advice New hot water heater/PEX Yesterday at 12:27 PM
Plumbing Forum, Professional & DIY Advice Occasionally hearing water running through vent stack, but no water is running. Wednesday at 6:13 AM
Plumbing Forum, Professional & DIY Advice It's Hot! Drink some more water. Wednesday at 3:38 AM
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice What's in a glass of water? Feb 18, 2017
