Water going on and off inside the walls
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by donnac36, Dec 27, 2008.
  1. donnac36
    donnac36 New Member
    Dec 27, 2008
    I keep hearing water going on and off inside the walls. No one is flushing toilets or running the water. I have a septic system. What is causing this?
  2. Terry
    Aug 17, 2004
    I would check for leaking flappers on your toilets.
    The tanks may be refilling.
  4. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    What Terry said. One way to check this. as long as your not sing any drop in bowl cleaners that changes the color of your water. Just before you go to bed add food coloring to the tank of water in the water closet. DO NOT FLUSH. let it sit over night and in the morning give a look if you see the food coloring in the bowl that means the flapper is leaking and needs to be replaced.
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Even easier is to close the stop valves on all your toilets and see if the noise goes away. If it does not, check your water meter to see if it is spinning.
Similar Threads: Water going
Plumbing Forum, Professional & DIY Advice 120 PSI fresh water from town - Going to install a PRV Sep 7, 2013
Plumbing Forum, Professional & DIY Advice Am I going to loose a water pressure in the shower head? iBox Dec 10, 2011
Plumbing Forum, Professional & DIY Advice Water not going down toilet but goes down drain fine Sep 21, 2011
Plumbing Forum, Professional & DIY Advice how to stop hot water going cold over long distance? Mar 13, 2010
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question 39 minutes ago
