Water Furnace Loop ATSM-D2666 Polybutylene
Discussion in 'HVAC Heating & Cooling' started by indytriker, Sep 1, 2011.
  1. indytriker
    indytriker New Member
    Sep 1, 2011
    Indy
    Dummy me got into the loop with a backhoe. This was installed in "88. I have been told this tubing might not be fixed due to no parts. All I need is a 8' of tubing welded in. Is this a possibility or am I in trouble. It is Water Furnace Earth Loop 1" blue tubing.
    Thanks in advance.
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Sharkbite makes couplings specifically for Poly B to pex. So 2 of them with a peice of pex in between should do it.
  4. indytriker
    Sep 1, 2011
    Indy
    Sharkbite doesn't have a 1" PB connector that I could find.
    Now what?
Similar Threads: Water Furnace
HVAC Heating & Cooling Converting Garage to living space and water heater/furnace venting req Oct 29, 2013
HVAC Heating & Cooling hooking hot water heat thermostat to furnace in attic Mar 18, 2013
HVAC Heating & Cooling Can I shut off return valves (water) on my furnace? Honeywell valve failed... Aug 14, 2011
HVAC Heating & Cooling Water? in the bottom of furnace/AC cabinet Jul 22, 2011
HVAC Heating & Cooling I need help cleaning the hot water coil in my oil fired furnace. Jun 3, 2010
