Water for Icemaker
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Robert May, Jan 11, 2013.
  1. Robert May
    Robert May New Member
    Jan 4, 2013
    Wayland, MI
    Should I supply hard water or soft water for the icemaker on my new refrigerator. Both are available with about the same difficulty.
  2. big2bird
    big2bird IBEW Electrician
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    I am quite sure you do not want to ingest soft water.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Why not? I use only RO filtered "soft" water for ingesting.
  5. hj
    The only reason for not ingesting soft water would be if you are on a low sodium diet. RO water is NOT the same as "soft water". Hard water will give you cloudy cubes because of the suspended minerals in it. Some sites will say not to us RO water, but my icemakers, and others I service, have used it for decades without any problem, and with clear cubes.
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Just how much sodium do you expect to get from ice cubes to make it a concern?
    True. It is softer. RO filtration can affect the pH and also being the "universal solvent" that it is, can be "aggressive" in dissolving some metals such as copper.
    Yes, I do get nice clear cubes from RO water.
  7. big2bird
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    I use my RO to feed my icemaker also. When he said "soft water" I assumed he meant a salt water unit.
  8. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Even so, the amount of sodium that would be added to the diet from ice cubes made with soft water is so minuscule as to be laughable.
  9. toddo
    toddo New Member
    Feb 25, 2006
    Pennsylvania
    Longtime lurker, first time poster. Slight hijack, please.
    Whole house remodel, ran copper for an icemaker, figuring it would come off a RO filter under sink. Heard a few theories about compatibility of RO water and copper, wondering what the collective wisdom of this board is. Copper is buried in wall.
    TIA, Todd
  10. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    You shouldn't use copper after the water has been treated by a RO unit.
  11. jadnashua
    THere's a reason water is called the universal solvent. RO treated water is quite aggressive and is much more able to attack (dissolve) things verses more common water that contains minerals. Probably not a good idea to use it with a copper line.
Similar Threads: Water Icemaker
Plumbing Forum, Professional & DIY Advice did my contractor use the proper water pipe for my icemaker Sep 4, 2011
Plumbing Forum, Professional & DIY Advice water line to icemaker in fridge Nov 29, 2010
Plumbing Forum, Professional & DIY Advice Icemaker make-up water slow Jun 12, 2010
Plumbing Forum, Professional & DIY Advice Braided Stainless Steel or Copper for my Water Filter and Icemaker? Nov 19, 2008
Plumbing Forum, Professional & DIY Advice Help tapping waterline for icemaker Jan 28, 2008
