Water Flow by the Well cover
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by cajunsally, Mar 26, 2006.
  1. cajunsally
    cajunsally New Member
    Mar 20, 2006
    I have a deep well with a jet pump. Recently there has been a slow steady trickle of water coming from where the well cap is. What could be the cause of this problem?
    Lately, when the power for my street has gone out I find that I lose my prime and have to restore pressure and water to my pump before it will continue to work.
    Is there a reason for losing the prime other than using the water while the power is out?
    The pump pressure gauge is 40-60 right now.
    any suggestions?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I would find out what that leak is and fix it.
    bob...
  4. cajunsally
    Mar 20, 2006
    Does this mean digging up the ground?
    This could be problamatic. LOL
    Question: I have good pressure and flow. I have a deep well jet pump. Could the pipe that shoots water down the well to force the water up have a crack in it. Would this cause water to flow out?
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Are you losing pressure when the pump is off and there is no water demand? That would indicate a leak in the system. It could also cause loss of prime when power is off.
    The drive water is usually the casing. See diagram at this link. http://www.peekspump.com/ejectors.html
    If the casing is leaking near the top of the well, then it could be leaking to the ground. When the power is off it might be possible to leak air into the system.
    You could test for a large leak by shutting off all water usage in the house and watching the gauge to see if you lose pressure.
    You might test for a small leak if you can shut off a valve between the pump and the tank and see if a gauge on the pump side of that valve holds pressure. That gauge should drop quickly if you have a leak on the pump side of the tank.
  6. cajunsally
    Mar 20, 2006
    Well I suppose I do have a leak, I have noticed that the pump goes on without any water usage on a regular basis. Also what I thought was ground seepage, is not. There has been no rain for an extended period of time and the leak by the well is increasing.
    I plan on digging up the area, when I get to the well casing what should I expect? Can the casing be replaced?
    is it possible it is just the pipe is cracked?
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Since you said you have a well cap. I am wondering if you have a pitless adaptor or if your not in an area where it freezes, you may just have a well seal. Do you see any pipes exiting this cap or do you just see a big pipe with a cap on top?
    bob...
  8. Bob NH
    Oct 20, 2005
    New Hampshire
    If it is a 4" well you might want to replace the pump with a submersible. You would have a lot less grief in your life.
    It is even possible, but more expensive, to get a 3" pump that would do what your deep well jet will do.
  9. cajunsally
    Mar 20, 2006
    ok, I'm digging. the cap I am refering to is a pipe, steel i think because it is rusted, six and half inches in diameter and sticks above the ground about three feet.
    It is about two feet behind a stone wall, which i am dismantling, which is about two feet high.
    So far I dug eleven inches down and have hit a cap? I don't know yet.
    When I turn the pump off by the circuit breaker it seems to hold the pressure.
    If I turn off the supply from the pump to the house, it just sinks to zero.
    What does this mean?
    How long would it be safe to let this happen?
    It is 4:26 pm and I need to work tomorrow.
  10. cajunsally
    Mar 20, 2006
    I live in Connecticut, it is 67 degrees out now but will probably be below freezing tonight, lol.
    I haven't found the pipes yet, still digging. Took out two holly bushes though.
    And I am pretty certain it is a deep well. 80 to 200 feet?
  11. cajunsally
    Mar 20, 2006
    I dug out a fair amount, haven't unearthed the cap yet, but I have two holes filled with water.
    I will continue when I get off work today, but it is supposed to rain tomorrow.
    Still digging
  12. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Filling with water can be a major problem.
    Your not looking for a cap, your looking for a pipe coming out the side of the big pipe you see coming out of the ground. It should be between 3 - 6 feet down.
    Good luck.
    bob...
  13. cajunsally
    Mar 20, 2006
    Could the cause of the flow be caused by a bad check valve?
    How would I check this?
  14. speedbump
    Jul 15, 2005
    Riverview, Fl.
    If you mean the leak you see, no. The check valve only stops the water from going back into the well after the pump turns off.
    bob...
  15. cajunsally
    Mar 20, 2006
    Striking Gold
    OK, I dug down about 3- 4 feet. Found the two pipes coming out of the stack. The top pipe had a plastic fitting with a tiny crack in it causing the leak. I replaced it, but I can't get the pressure to come up now with the pump.
    I thought I primed it properly. I tried to bleed all the air out through the valve on top. And I tried to adjust the cut-in cut-out pressures.
    Is there any thing else I can do.
    And thanks for all your input. I really, really appreciate it.
    Cajunsally
  16. speedbump
    Jul 15, 2005
    Riverview, Fl.
    You can attach a hose from your neighbors to your outside faucet. You will need a double female fitting to make this work. A washing machine hose works also.
    Turn on both faucets and leave the prime plug loose to let the air bubbles out. When all you have leaking out is water, turn on the pump. It should go.
    bob...
  17. cajunsally
    Mar 20, 2006
    OK, Can you tell me where the prime plug is.
    I have a Goulds j7 pump
    deep well, two pipes,1 1/4" on top and 1 " on bottom.
    I see two hex nuts in back. one near top center.
    The other bottom left, and a little bigger.
    I am going to try the one near the top, since this is where I want the air out.
    Wish me luck... thanks again
  18. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I am not real familiar with Goulds model numbers. Most pumps either have a prime plug of 3/4" or 1" on top of the pump or the installer is expected to put a priming tee in the only outlet to make priming possible.
    I have seen many DIY installations that I have no idea how they primed the pump, since they used an elbow instead of a tee with a plug in the top.
    The important thing is, to get the pump full of water. Then it should prime.
    bob...
  19. Bob NH
    Oct 20, 2005
    New Hampshire
    The Goulds J7 has a 1" outlet on the top. You need that tee with a plug in the top that should have been installed with the pump.
  20. cajunsally
    Mar 20, 2006
    Well , I went to Lowes and got the tee valve and adapter to prime. Instead I rear ended someone in the parking lot. My day went from bad to worse. There was plenty of water, so I called the well guys. They pulled up the well and there was a tiny screw head stuck in the venturi of the foot valve. All is well now. I have water ,,,, Thanks for all the input. I learned a lot.
Similar Threads: Water Flow
Pumps and Tanks Well Forum & Blog. Water is life. Water Not Flowing Into House, Is It The Pump? Feb 24, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water Softener Sizing (Flow Rate) Feb 2, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Aluminum Hi-Flow Water Pump Aug 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Water dirty brown after home inspector's flow test Jun 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Disconnect roof drain pipe or pipe the water into the sewer before backflow preventer? Jan 19, 2015
