Water dripping from end of shower arm
Discussion in 'Shower & Bathtub Forum & Blog' started by Shark Ram, Dec 2, 2005.
  1. Shark Ram
    Shark Ram New Member
    Dec 2, 2005
    First thought I had a leaky shower head, but it checked out fine. When I removed it, water still leaks from the end of the shower arm. Took off the cap and unscrewed our Moen tear drop knob to tighten the inside valve, but it's still dripping. What else can I check?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    The culprit should be the cartridge. I suggest replacing it.
    It should be this
    [​IMG]
    Or this
    [​IMG]
  4. hj
    leak
    Showeer heads do not leak. The valve that turns the water on and off leaks. Tightening the cap on many new valves does not stop a leak, it just makes the valve harder to take apart when you decide to fix the real problem.
  5. Shark Ram
    Dec 2, 2005
    Cartridge replacement fixed it!
    Thanks for all the advice! I got the Chateau Posi-temp Tub/Shower Replacement Cartridge (Moen part#1222) at Home Depot. The Home Depot guy said I didn't need the cartridge puller tool because a twisting tool (white piece) that already came inside with the cartridge would do the trick.
    However, I read on many sites and on this forum that sometimes that thing doesn't work, so I bought the pulling tool anyway...just in case.
    Got home and followed the instructions provided with the cartridge. So far, so good, until we got to actually pulling the freak'n thing out with the little white twisting tool they supplied. I'm not what you call a "petite man"...so I kept pulling on that sucker and it wouldn't budge. The wife thought I was going to yank the pipes out of the wall, so I went to the shiny pulling tool I bought and a few minutes later, out slides the cartridge.
    Put everything back together, turn the water back on, crossed my pliers, feet, whatever...and asked the wife to turn the shower on/off for testing. To my relief, NO MORE LEAK!!! Many thanks for all the advice!
Similar Threads: Water dripping
Shower & Bathtub Forum & Blog Need advice on fixing Delta 600 shower/tub valve - dripping water Oct 16, 2013
Shower & Bathtub Forum & Blog Bath tub hot water dripping Feb 17, 2008
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Feb 27, 2017
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Feb 15, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
