Water does not completely divert from spigot to shower head.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by matapus, Dec 12, 2008.
  1. matapus
    matapus New Member
    Dec 12, 2008
    I have a shower with 3 knobs. one hot, one cold, and a center one for shower or tub. when you turn the knob for the shower, the water keeps coming out of the spigot. how do you adjust this? thanks.
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    that is normal
    That is a Sayco faucet...
    what you hav ein your hand is either a hot or cold stem..
    for the center stem in the sayco faucet you need a special
    diverter stem...
    you can put in a new diverter stem in the center
    and it might make it do a better job...
    but it is normal for some to come out of the spout all
    the time
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    You can also try to rebuild the diverter stem by replacing the worn-out bibb washer, o-rings, and any other seals. I also like to add a bit of plumber's grease to the inside threads.
  5. jimbo
    jimbo Plumber
    [​IMG]
    Your middle ( diverter stem ) probably looks like this. Get a new one.
    TIP: When removing or reinstalling any of these shower stems ( hot/cold/diverter) make sure the stem is turned to midway bewteen open/close positions.
Similar Threads: Water does
Plumbing Forum, Professional & DIY Advice Main Water Line Basement Entrance - Does this look OK? Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Does homeowner insurance usually cover water leaking fix(e.g. repipe or reroute)? Nov 14, 2016
Plumbing Forum, Professional & DIY Advice How does my hot water reciculation setup look? Jul 8, 2016
Plumbing Forum, Professional & DIY Advice Why does my cold water turn warm? Delta Shower Valve Mar 28, 2015
Plumbing Forum, Professional & DIY Advice Does grundfos make 230v thermostats for hot water recirculator pumps? Jun 22, 2014
