Water coming up from shower drain
Discussion in 'Shower & Bathtub Forum & Blog' started by ofabiano, Dec 30, 2009.
  1. ofabiano
    ofabiano New Member
    Dec 30, 2009
    WI
    I have water coming up from shower drain when turning on bathroom sink and it only takes a few seconds for this to happened. Water does drain but very slowly. I've used all of a 25ft snake a few times on the shower and sink drains but still have problem. Did get some hair but not a lot.
    Before purchasing the snake I tried blowing air through the shower drain but water came up through the sink and there was chunks of soap scum and hair.
    I did this again after using the snake and this time it was cleaner.
    Should I use snake a few more times or should I buy a longer snake? Or is there a bigger problem?
    Thanks
    The toilet in the bathroom works fine.
  2. CountryBumkin
    CountryBumkin Active Member
    Sep 4, 2009
    Orlando, FL
    I had this happen to me. the problem was in the main sewer line exiting the house (well downstream of the bathroom). It was partially clogged. Since the shower drain is the lowest point in my house plumbing that is where the water backed up when there was more water going into the sewer line than was able to leave. I thought my septic tank was full so I called a professional. Turned out the line exiting the house was clogged with fat/grease.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You're on the right track, but you're sending a boy to do a man's job.:D The snake you are using may very well be too short, but it is also very possible that the diameter is too small and is just poking a hole through the clog. This is the time DIY usually isn't going to cut it. You need a plumber who has the 3/4" snake with a large cutting head to auger the drain. A plumber will run the snake all the way to the sewer main/septic tank. Most of the pros on this forum advise you call a plumber who does not have "Rooter" in the company name although there are probably some of them who will do a good job, there are some flakes.
  5. hj
    snake
    Unless you bathroom is larger than one in the Waldorf-Astoria, a 25 foot snake is at least twice as long as necessary, IF it is being used properly. WE cannot tell why the drain is still plugged, but it is.
Similar Threads: Water coming
Shower & Bathtub Forum & Blog Moentrol, Only hot water coming from Moen shower Aug 11, 2016
Shower & Bathtub Forum & Blog how to stop water from coming out facet instead of shower head Sep 25, 2013
Shower & Bathtub Forum & Blog No cold water coming out of shower/tub Jan 25, 2013
Shower & Bathtub Forum & Blog "Running Water Sound" coming from behind the walls - What could be the cause? Jul 13, 2012
Shower & Bathtub Forum & Blog AquaSource faucet = No water coming out Dec 11, 2011
