Just found this site on the web. Great site, I can tell I'll be doing alot of reading here.
I'm about to start to finish my basement in our 3 year old house. I decided to start at the sump pump which runs ever 10 minutes for about 10 seconds raining out or not, summer or winter. Just thought this might be normal becasue we're very close to a big lake and about 600 feet from a canal.
I thought I would start with replacing the cheap pump the builder put in with a Zoeller M-57 or M-98 and install a backup system and clean all the junk out of it that's on the bottom. As I sucked it all out along with the water, I noticed water coming in quickly from the bottom from what looks like a 1/4 or 3/8's hole but not sure.
What to do? Is this a problem? Should I replace the basin(hope note)? Try to plug the hole? Leave it alone? Why is water coming in, is it below the water table?
One other thing, even without the hole in the bottom, water is always draining in from the tile feild at about the same rate as what was coming up from the hole. I guess we are just in a wet area with the big lake close by and the pump is still going to run a lot, just not every 10 minutes, maybe every 20.
Thanks for the help
Rich
Thanks for the help
Rich
