Water cartridge on well system warped
warrens
quebec
Hi. I have a simple rain fresh whole house water filter on my water system. Artesian well.
I have a low producing well with a (600 litre reservoir tank inside the house)but when I came home today the reservoir was dry but it was full before I left so it looks like a toilet or something has been leaking
However the filter cartridge was now stopping water entering the system and it is warped. So rather than being two parallel sides it is concave. I changed the filter and water enters properly
Any ideas what could have caused this- pressure buildup?
Thanks for any help
I think you are saying that you have a cartidge filter between the well and the reservoir tank. What is the order of things in that path-- well, first shallow jet pump, filter, something thing else, reservoir tank? I presume that first pump controlled by a float switch.
It sounds as if the filter clogged. Usually the unfiltered water is on the outside of a cartridge. That would let the pump create a pressure that could crush a pleated element I would think.
http://rainfresh.ca/sediment_filters.php
Craigpump
I've seen that happen to a pleated paper element, we changed to a foam style element and never had another issue.
