Water Bubbling from ground outside pump house
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by 5berryfarm, Jan 10, 2012.
  1. 5berryfarm
    5berryfarm New Member
    Jan 10, 2012
    Oregon
    I just noticed that our pressure tank was running constantly. Then I found two small holes in the soil outside the pump house where water was bubbling up and now the ground in that area is saturated. Both holes are located on the same side of the pump house. I just shut the water off...and the bubbling stopped immediately. We still had good pressure and water to the house....until I shut it off. What could the problem be?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    You have a hole in the pipe.
  4. 5berryfarm
    Jan 10, 2012
    Oregon
    Thank you for the reply. I got impatient waiting for my husband to get home so I started digging. Luckily I found the issue (I think) fairly quick. It is a joint that is about 2 feet from the well house. I shop vac'd out the hole and then returned the water to light pressure...the joint started spurting and spraying water. There is a LARGE hole/void in the ground just underneath the joint. Does the joint need to be replaced all together or ??? There does not appear to be any cracks or breaks in the pipe. It seems as if the joint slipped....like the sleeve was too short?? Here is a photo http://i883.photobucket.com/albums/ac32/allequinesales/Pipe/Pipe.jpg
  5. greenmonster304
    greenmonster304 New Member
    Apr 16, 2011
    Hampton Bays, NY
    You need to cut out the old coupling and replace with a short piece of pipe and one of the following knock on coupling, compression coupling, 4 90's, or slip fix.
Similar Threads: Water Bubbling
Pumps and Tanks Well Forum & Blog. Water is life. House on a hill with no water pressure Today at 7:49 AM
Pumps and Tanks Well Forum & Blog. Water is life. Well Water Sunday at 8:20 AM
Pumps and Tanks Well Forum & Blog. Water is life. Acid Neutralizer/Water Softener Mar 21, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pump runs continuously while water is on. Mar 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wayne PC2 - Do I need a water strainer? Mar 11, 2017
