Water Backup into Bathtub when using sink
Discussion in 'Shower & Bathtub Forum & Blog' started by johnnyportable, Feb 28, 2006.
  1. johnnyportable
    johnnyportable New Member
    Feb 28, 2006
    HELP! As my wife was using the sink this morning the water started backing up in the bathtub and the standup shower. When we flush the tiolet the water does not go down and then as I try the plunger it the water backs up into the bathtub and shower again. The other bathroom upstairs is fine and so is bathroom downstairs. The house is only 3 years old. I'm at a loss. Thank you very much in advance. :confused:
  2. jadnashua
    Sounds like you have a clogged main drain line. Usually, these things don't block everything, but will slowly let some of the waste run by. So, upstairs has the full veritcal height of the pipe to fill up before you'd notice a problem. The clog is below the lower floors drains. Don't try chemicals to clean it out, you need a proper snake to clear it out.
  4. johnnyportable
    Feb 28, 2006
    Thank you jadnashus.
    Where would I need to use the snake at? I suppose into the toilet? It would have to be a very long one I suppose? Is this something I could do myself or would you recomend a plumber? Can you recomend a snake to do the job?
    Again Thank You!
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Don't do a load of wash and go away either.
    Do you have septic tank or city sewer?
    Do you have a basement and do you know where the large clean outs for the sewer are?
    Have you noticed the kitchen and laundry are part if this situation?
  6. johnnyportable
    Feb 28, 2006
    The only problem seems to be in the master bath. Other two bathrooms are fine.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Very ofter DIY snakes are too light weight to get serious clogs, in fact, often it makes a clog worse be just pushing it deeper into the drain. My advise to you is to have the drain professionally augered. Yes, it will cost a few dollars, but if they don't get it the first time, they get to come back on there own dime. As previously noted, do not use chemical cleaners.
Similar Threads: Water Backup
Shower & Bathtub Forum & Blog Water backup in tubs and toilets when running washing machine, please help!!! May 24, 2005
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Feb 15, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Faucet wall tubes and wall tube escutcheon is not water tight Feb 9, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
