Water Around Top of Well Casing, Pressure Fine
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by danmoliver, Apr 12, 2014.
  1. danmoliver
    danmoliver New Member
    Apr 11, 2014
    Ontario
    Hi,
    This spring after all the snow melted, I noticed water around the well casing at the top of the ground. So I am pretty sure there is a leak somewhere (possibly in the pitless adaptor), but we are on an artesian well (and it has enough natural pressure that water goes right to the top even with pump not running) so water pressure is fine in the house and really the water is drawn much lower than the actual leak point of course.
    So the question is, it would be nice to fix it of course but do I NEED to fix this? Will it be ok through next winter too?
    Just found out we need a new furnace last week so looking at $5000 for that and I don't want to spend an extra $1000 plus to dig up the well, pump rental, etc... to fix this.
    Thanks,
    Dan
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    An ounce of prevention is worth a pound of cure. It may not take much to fix the leak now, but the longer you wait the more damage it can cause.
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Based on what you wrote, I'm guessing you cannot see where the water is leaking out. If you are sure that it is not overflowing the top, then it could be leaking at the pitless. There are in fact two seals at the pitless. One seal is on the connection between the casing and the pitless and if that one is leaking, there is a strong possibility that surface water is also getting into the well and could contaminate it, if the water level in the casing ever drops below ground level.
    If you can pump the level down below the pitless, then drop a camera down the hole and see if groundwater is leaking into the casing. If it is, dig it up and fix it. Hopefully it was backfilled with something easy to dig in. My pitless is 8 feet down and this area is pure clay but I made sure the contractor filled the trench with sand JIC I had to dig it up in the future.
  6. danmoliver
    Apr 11, 2014
    Ontario
    Thanks for all the responses. I thought I would go ahead and get it excavated but when talking to a plumber, he actually said that because it's an artesian well, if it wasn't cemented properly then it's possible that there is water coming up right along the outside of the pipe - right to the top.
    I do notice that if I run the water in the house, then the water right on the outside of the well casing will very slowly go down, so not sure about this.
    There was a lot more melting this year where we are and the plumber talked himself out of a job by saying what he told me, so I can trust him and really I did anyway.
    Thoughts? Anyone ever heard of this happening?
  7. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    If the casing isn't properly sealed as you plumber suggested, your well could become contaminated. You need to have this checked out by someone who has a down hole camera so they can inspect the drive shoe and joints in the casing.
  8. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Normally, during the drilling process, a slurry of bentonite is used which should seal between the borehole and casing.
    If that is in fact happening, it strongly suggests that there is leakage and it would likely be bi-directional meaning it could contaminate the well.
    You don't say how old this well is and if you commissioned the drilling. I would try to get the driller back for his opinion and maybe advise the regulatory board of the situation if necessary.
Similar Threads: Water Around
Pumps and Tanks Well Forum & Blog. Water is life. Water flooding around well casing and low pressure in house. Mar 29, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Water is shooting up around casing Jun 28, 2006
Pumps and Tanks Well Forum & Blog. Water is life. Chlorine adding to well water. Apr 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Which City water pressure booster pump is right for me to increase PSI ? Apr 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Help understanding well...water coming out of top Apr 10, 2017
