FatDaddy
I have an odd situation and will do my best to explain with thanks in advance for any advice given.
A brief explanation to the photo:
The riser has a clothes washer discharge in it and is 18" above the assembly leading to the 4" cast iron line that
leads to a drywell outside.
The line leading to the left goes to a slop sink about ten feet away.
The 2" pvc drains the kitchen sinks.
My issue is that for a long time I have seen signs in the sink of a small backup. It seemed to occur when the washer was discharging. Last night it almost filled the sink with really nasty black wasterwater and the sink did not drain at all. When I inserted a garden hose in the riser, water backed up into the sink.
I vacuumed the water out and called my septic guy.
He and I put fifty+ gallons of water into the slop sink and it drained strongly. Without a cleanout cap on the 4" he could not use a big snake and he could not send a snake down the riser due to the bend. He went in via the pvc.
It SEEMS as though the water backs up when the washer is discharging and additional water from either upstairs or the slop sink is entering the system. My guess is that the 4" line to the drywell is as clear as any seventy year old line can be.
Any thoughts about my predicament? I am $200 poorer and nothing has changed. I will reconfigure the piping to include a cleanout cap but wonder if the current configuration is the problem.
