Waste plumbing diagram pics
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by homeguard, Jun 13, 2008.
  1. homeguard
    homeguard New Member
    Jun 12, 2008
  2. hj
    dwv
    Get a plumber.
  4. jimbo
    jimbo Plumber
    I am getting the same pic on both links????
  5. hj
    link
    Originally there were two drawings, neither of which would pass any code if installed exactly according to the drawings.
  6. homeguard
    Jun 12, 2008
    these are just sketches, what exactly will not pass on the code? i had a guy at the code services office look at them and he said they would pass... and why would i need a plumber isnt that what this forum is full of?
  7. hj
    drains
    For starters, you do not show any vents for the lower level, and none of the vents on the upper level are functional if placed where you show them. This is not a DIY course in plumbing. It is to help people to DIY what they can, tell them when it is not a DIY project when they shouldn't, and mainly, help them to see the difference. YOU are trying to take on a job that you may not have the experience or talent for. IF you can do it, good for you, but if you install it according to that drawing, regardless of what the "counterman" says, the real inspector should reject it and require that it all be taken out and redone properly.
  8. jimbo
    jimbo Plumber
    Again, I can only see the "old" picture. We will assume that you just drew a rough layout, and the fittings and tie ins are actuallly OK to code.
    The hard part about adding to the lowest level is that you do not have any vent down there. A new vent pipe will need to connect from there all the way up to the third level to tie in. Can you post another drawing of what you want on the lower level?
Similar Threads: Waste plumbing
Plumbing Forum, Professional & DIY Advice Plumbing Kitchen Sink. Need Advice on Waste Line. Sep 30, 2015
Plumbing Forum, Professional & DIY Advice Plumbing waste and vent layout for new construction Jul 18, 2014
Plumbing Forum, Professional & DIY Advice How professional are these plumbing waste and vents? Oct 24, 2012
Plumbing Forum, Professional & DIY Advice Please Help with Kitchen Sink Plumbing! Waste Pipe is too high May 18, 2010
Plumbing Forum, Professional & DIY Advice Proper double sink waste plumbing, with Disposer? Apr 26, 2009
